Introduction: Ghoul Grabber
In this instructable I will be teaching you how to build:
A step sensor for less than a dollar (or even free!) (I was the first to post this!)
A delayer(to power your items for a given amount of time (the most simpe way possible)
And a ghoul grabber
That's right, you get 3 for the all low price a couple of dollars!
The step sensor is steps : 1-10
The delayer are steps: 10-15
The ghoul grabber is steps: 15-27
Trick-or-Treat!
And a ghoul grabber
Trick-or-Treat!
Step 1: The Step Sensor
You can make a good, reliable sensor for less than a dollar! All you need is some aluminum foil and paper! This type of sensor is really just a giant momentary, normally on, switch.
Step 2: Materials
Roll of heavy duty aluminum foil
A roll of paper (used in stuff like type writers and god knows what, you can buy them new or at garage sales/thrift stores)
That's it!
That's it!
Step 3: Measure You Walkway
measure the walkway in front of your house that leads to your door. Mine was 42 inches wide
Step 4: Cut the Paper
cut 6 strips of paper so that the length of each paper is 2 inches longer than the width of your walkway, so I cut each piece of paper 44 inches long.
Step 5: Cut the Aluminum Foil
Cut the aluminum foil the same length as the paper, but this time you only need two sheets.
Step 6: Tape the Paper
tape two sheets back together so that it's now almost 2x as wide as before. Do this 3 times so you have 3 sheets of paper. This step is necessary because the width of the aluminum foil is wider than the paper.
Step 7: Turn Paper Into Fish Gills
using your hobby knife, cut strips out of one of the sheets of paper. Make sure that each strip is less than 1 cm wide or you'll run into problems later. The design of your cuts do not matter.
Step 8: Glue Foil to Paper
glue one strip of aluminum foil to one of the sheets (one of the non cut-up ones) in the center. Do the same for the other one. Now you have a sheet of paper with aluminum foil stuck to it, a paper that looks like gills, and another sheet that has aluminum foil glued to it.
Step 9: Put It All Together
sandwich the layers of material like this:
paper
aluminum
gill paper
aluminum
paper
paper
aluminum
gill paper
aluminum
paper
Step 10: Tape It and Your Done
tape the edges together (not too tightly) and you're done! Whenever you step on it the 2 pieces of aluminum foil touch, acting like a momentary switch.
Step 11: Delayer/timer
now you have your sensor you need a delayer. What this does it keep your motor (or whatever) on even after you step off of the sensor for a predetermined time.
Step 12: Materials
breadboard
electrolytic capacitor(s)
12volt spdt relay (from radioshack, I used this one )
jumper wires and alligator clips
Step 13: Choosing a Capacitor
I used 3 capacitors (I couldn't find one big one) in parallel to get my timing device. When choosing your capacitor about 1100 uF equals 1 second. so to get 5 seconds (I think it's a good time) then use 5500 uF.
Step 14: Schematic
can't really help you hook everything up, but here's the schematic I came up with.
Step 15: Hook It Up
hook all of the connections up and your done! I used a breadboard because halloween is one day a year, and I want to keep my parts, such as the relay.
Step 16: The Ghoul
the ghoul is the main part of this instructable, yet can be made within an hour for mere dollars.
Step 17: Materials
motor (make sure it's strong, mine wasn't strong enough so I couldn't add to many decorations)
a skull (picked up at Michaels for 5 dollars)
2x 24 inch piece of wood
2x 20 inch piece of wood
1x 12 inch piece of wood
1x 6 inch piece of wood
1x 4 inch piece of wood
NOTE: the kind of the of the wood doesn't really matter, between 1 and 2 inches wide are good, the thickness of the wood should be kept to a minimum, like around 1/8 to 1/4 of an inch.
5 inch long dowel
some scrap wood
some big piece of wood for a base
old white dress shirt
8x nuts and bolts
a bunch of washers
5 inch long dowel
some scrap wood
8x nuts and bolts
a bunch of washers
Step 18: Drill the Wood
note that all holes are to be centered, but it doesn't matter a whole lot
note that all holes should be wide enough so that the bolt slips through easily (but not the head)
on both 2 foot pieces of wood drill a hole on each ends (about 1 inch from the end). Next drill a hole in the center of both pieces of wood. You should have drilled a total of 6 holes.
on both ends of the 1 foot piece of wood drill a hole 1 inch from the end.
for the 20 inch piece of wood line up the bottoms with the 1 foot piece of wood and drille holes so that it's like the 1 foot piece of wood, with more wood sticking out. the holes should be around 1 end, and the center.
for the 6 inch drill on both sides about 1/2 to 3/4 of an inch from the edge.
on the 4 inch piece of wood do the same as the 6 inch piece of wood
Step 19: Connect Everything
connect everything as you might expect with nuts, bolts and washers. the 2x 2 foot woods are parallel, the 12 inch wood bisects it, and the 2 20 inch woods extend from the ends of the 2 footers. Glue on the dowel a bit off center as shown in the picture. Don't worry about the 4 and 6 inch wood yet
Step 20: Make the Base
elevate a little island on your big board so that you can rest your structure on it. glue the board to the 12 inch wood like in the picture.
Step 21: Make a Crank
attach the 2 short pieces of wood as shown.
Step 22: Drill a Hole in the Structure
depending on how strong your 12 volt motor is you drill a hole in certain places. the stronger your motor the closer to the center you get, the weaker the motor the closer to the "arms" you get. Don't mind the motor in this picture.
Step 23: Attach the Motor
attach the motor to the crank you made.
Step 24: Attach to the Structure
attach the crank to the hole you drilled in step 22. You can then use a clamp to hold the motor down.
Your ghoul is now ready, you now just need to make it look scary!
Step 25: Clothe It
put a dirty shirt on the structure. if you want to you could even drop some red food dye for blood. I had to cut my shirt because my motor was too weak because the shirt was dragging on the floor.
Step 26: Glue the Skull
glue the skull onto the dowel and your done!
Step 27: Taking It Further
if you want to you could add on another relay and have that control power going to speakers that are playing ghoul like sounds. Alas I don't have an MP3 player or speakers.
YOU'RE DONE!!! WOOHOOOO!!!!!11 (<-see the one there?)!!! You should be proud!
