Introduction: Giant 3D-printed Poké Ball!
About: 👨‍🔧 Engineering | 3D Printing | Solidworks 🧠 Ideas to Reality, layer by layer ! ⚡ Powered by caffeine & PLA ⚙️Check my YouTube channel !
What really happens inside a Pokéball?
I may not have the official answer… but while thinking about it, I ended up building my own giant, handmade Pokéball — and this project became a fun mix of craftsmanship, problem-solving, and pop-culture inspiration.
In this Instructable, I’ll walk you through:
  1. Planning and designing the overall structure
  2. Building the internal frame
  3. Creating and shaping the outer shell
  4. Painting and finishing to achieve the classic Pokéball look
🎥 Want to see the final result in action?
https://youtu.be/exD7GZWry_w
Time to bring a bit of the Pokémon world into the real one! 🔴⚪⚙️
  1. 3D Printers,
  2. Prusa Core ONE
  3. Prusa XL
  4. https://www.prusa3d.com/category/3d-printers/
  5. Table Saw
  6. Artisan CNC
  7. https://www.snapmaker.com/en-US/snapmaker-artisan
  8. 15mm Plywood
  9. 20+ kg PLA
  10. 10 kg
  11. and a lot of patience
Step 1: What Happens Inside a Pokéball?
It’s a simple question — yet one that’s gone unanswered for over 20 years.
Searching online, I found several theories.
For example, in the Pokémon manga, Pokéballs are transparent, so we can see what’s inside. But honestly, it’s kind of sad to see those little creatures all cramped up.
Then I found that not long ago, the animated series explained that the interior is more like a cozy chamber where Pokémon can relax.
Finally, I stumbled upon this image on Reddit of a Pikachu chilling inside a Pokéball — and that’s when everything started to click in my head.
What if I built the same thing… but for humans? How hard could it be? Has anyone done it before?
My first instinct was to check YouTube for tutorials or similar projects. I didn’t find a tutorial, but I did find the spark of inspiration that pushed me to start this journey: the Corridor Crew video showing the special effects of what the inside of a Pokéball could look like.
If you haven’t seen it, here’s the link 👇
Step 2: 3D MODELING
Let’s start with the 3D model. Designing a sphere isn’t complicated — that’s true. But before I began, I had so many questions: How big should it be? What material should I use? Which fabrication method? Should I make it by hand? I decided to focus on the essentials first — the overall dimensions.
I took a piece of wood and improvised a compass to draw circles on the floor, just to visualize the inner space. The diameter would be 1.7 meters (around 5.6 ft).
With that, I realized the project wouldn’t be cheap. Oh! By the way, I’ll share the approximate costs throughout this article. And I also needed a strong structure.
I chose plywood — affordable, sturdy, and easy to find. Then I began the 3D modeling, imagining how a curved piece (which I’ll call a “banana”) could be replicated around a central point to form a semi-spherical frame.
Once I had half the structure, I mirrored it to get something close to a full sphere. I added some top supports to reinforce the bananas and modeled a small door, since I’d need to get inside — maybe even with other people, in case I show it at a Maker Faire or a pop culture event.
We’ll pause the 3D model for now — I’ll talk about the interior later. Let’s move on to fabrication!
Step 3: PRE-STUDY
Before going for CNC cutting, I decided to cut the parts at scale with my laser cutter. This helped me realize a few things: wood is flexible, so I’d need intermediate supports, and thanks to my friends at3DEMON (who provided an Ash Ketchum model),
I saw that the center space was too small for a person’s feet. Small details, yes — but lots of them, and those can cost both time and money later.
Step 4: CNC Cutting
Since I chose wood as my main material, I knew I’d need help — I don’t have a CNC cutter big enough for this project. So I called my friends at Exokit in Saint-Brieuc, France. They build van interiors, so when I told them about this idea, they thought I was joking. But they didn’t say no — and that’s how I ended up in their workshop to prepare the cuts.
In total, I used three plywood sheets of 3 × 1.8 meters (9.8 × 5.9 ft). Material + cutting cost: about €700.
Step 5: Assembly
Seeing all the cut pieces really boosted my motivation — the idea was finally taking shape!
The assembly went just as I had imagined, thanks to the small-scale model I’d built beforehand. I used wood glue and stainless steel screws, plus some guides to keep the spacing consistent. Assembling everything took a few days. It was fun but also challenging — even with CNC cutting, small tolerances required some manual adjustments.
Step 6: The Big Challenge
Now we had a giant wooden ball. So… what next?
Covering it — and that turned out to be the toughest part. My first idea was to use 2mm MDF sheets, cut to follow the spherical shape.
At first glance, it looked great! But when I checked closely, I realized we weren’t getting a perfect sphere — it looked a bit too low-poly.
I tried adding supports, but MDF isn’t strong enough and broke easily. Honestly, it was like a cold shower…What now? I brainstormed like crazy: maybe fill it with expanding foam? Too expensive. Maybe use cheap filler material between the wooden walls — kind of like IKEA furniture?
That last one sounded reasonable, so I bought polystyrene insulation boards. I cut tons of them, but when I started installing, I hit another reality check: a sphere is not simple.
Each piece had to be slightly smaller than the last, and since I was cutting by hand, the result wasn’t great. I had two options: spend endless hours cutting, or find a faster solution.
That’s when 3D printing came to the rescue! I modeled a 3mm-thick shell to preserve the sphere’s roundness — finally, a viable solution!
But wait — how many parts would I need? How long would it take? In total: 26 sections with 8 levels each, and since my printers had limited size, I had to split everything in two. My friends at Prusa sent me Buddy and Prusament filaments to keep going, and another friend suggested using 0.8mm nozzles for faster prints — we didn’t need high detail. That “hack” put all my printers into production mode! The best part? While printing, I could already start assembling.
Step 7: Covering the Sphere
Covering the sphere took about a week. I joined the 3D printed panels using hot staples and attached them to the wooden frame with 4mm screws. It was a bit tedious, since not all parts had the same tolerances — I was using multiple printers (MK4S, Core One, Prusa XL), and each one produces slightly different results.
But hey, I had to work with what I had!
Step 8: POST-PROCESSING
Now that it finally looked like a real sphere, what next? Make it solid!
I found a resin online that adheres well to 3D prints, so I reinforced the structure with resin and fiberglass layers. It wasn’t easy — resin sticks to everything — but patience was key. Once it dried, I sanded lightly and applied spray filler, hoping to reduce post-processing work.
Reality check: it looked awful. I’ve done projects like a 3D printed Iron Man suit and even a 2-meter-long cannon, so I know what post-processing means. Even so, it’s not my favorite part. Still, I had no choice.
I used about 10 kilograms of filler, 95% of which ended up sanded away. Crazy, right? But it was the only way to get a smooth, paint-ready surface. Weeks went by. Some nights, I literally dreamed of sanding — because that’s all I was doing: sleeping, eating, sanding. The cost climbed from €700 to about €1000, including tools and materials.
Step 9: PAINTING
Finally — time for color! After all that sanding, the Pokéball was ready for paint. Nothing fancy here: just a bright red and white paint, no varnish needed. It was a 4:1 mix, easy to apply, and took two afternoons to finish.
Step 10: INTERIOR
Back to the 3D model — I had simulated how I could sit inside and designed some simple furniture: a TV stand and a spot for a Nintendo 64. Then I cut more panels on the CNC and installed them.
It was a bit slow, because the more I installed, the less room I had to move. I added electric wiring for the TV and console, just using a basic connector for now — I’ll improve that later.
For the seats, I used foam padding and red fabric, creating a sort of couch. It was my first time upholstering, and I did it with my wife — it was actually really fun!
Finally, my friends at DuneRock (Pokémon decorations) and DomyRugs (Pokémon rug) sent me some awesome finishing touches.
Step 11: FINAL RESULT
So, what really happens inside a Pokéball? In my case — it became a gaming room, a cozy place to relax and disconnect from the outside world. No phones, no internet — just me, an old TV, and my Pokémon games.
Please don't forget to support my creations at: https://www.youtube.com/@carlos3dworld
