Introduction: Giant Spinning Holographic Christmas Tree Display
What better way to celebrate the holidays than with a giant spinning extremely dangerous metal frame that can draw a Christmas tree out of thin air? I'm going to say it right now, you shouldn't build this. What you should do is watch the video.
- 1 × 1/2HP AC Motor with 1/2" Diameter 6" Shaft
- 2 × SK9888 LED Strip - https://www.adafruit.com/product/2241
- 1 × Raspberry Pi 4 - https://www.adafruit.com/product/4296
- 1 × 12V 10A Power Supply
- 1 × 5V Step down regulator - https://www.pololu.com/product/2881
- 1 × A Ton of 40mm Aluminum Extrusions
- 2 × 8ft 3/4 Aluminum U-Channel
- 1/2-20 Bolts
- 1 × Mounted Bearing for 1/2" Shaft
- 1 × Aluminum Plate 1/4"
- Lots of various metal pieces
- 6 wire electrical slip ring
- Hall effect sensor
Step 1: Don't Build This. Seriously.
I don't think I need to explain this, but step 1 is question yourself if you're ready to build something like this. Its a very dangerous centrifuge(as all are) and could seriously injure you or someone else.
Step 2: Build the Support Frame
Take the 40mm Aluminum extrusion and put together a frame that will support your motor and spinning tree. Rigidity is your friend here. But you probably shouldn't be building this.
Step 3: Built the Spinning Metal "Tree" Frame
You need to decide the dimensions you're going to use. I ended up with a tree around 4ft tall, and 32" wide. I then painted it black so it would "hide" more when spinning. Again, don't build this.
Step 4: Mount the Motor and Tree
You need mount the motor, install the slip ring, then mount the "Tree". Everything needs to be very well aligned or it won't spin. Build a mounting plate that fits your specific motor, then build a mounting plate for the bearing. Also don't build this.
Step 5: Build the Electronics
There is a great tutorial on Adafruit for the electronics for a light painter. This is basically a really dangerous spinning light painter so you can copy that circuit. Found here: https://learn.adafruit.com/dotstar-pi-painter
You can build the light painter, just don't build this.
Step 6: Wire in the LED Strip and Components
The LED strip needs to be attached to the slip ring so that you can give it power and data through the spinning shaft. Its where all the magic happens.
You also need to connect the hall sensor and mount a magnet to detect the position of the spinning tree
Step 7: Power It On
If everything is connected right, you should be able to power it on and test the LED strip at this point.
Step 8: Make Some Animations
In your favourite video software make some animations and export them as a JPEG sequence into their own folder. Each folder will be an animation.
Step 9: Run the Code
Again follow the Adafruit tutorial on building a light painter, then the code I modified that can be found on my GitHub. https://github.com/IdleHandsProject/pov_christmas_tree
Step 10: It Works!
Look at your magical digital Christmas tree! or just look at mine, because you shouldn't build this.
Step 11: Any Animation
You can put anything you want on here!
Step 12: Support These Projects
If you want to support my creations there are a few options
Subscribe to my Youtube Channel
Like and Share my stuff!
