Introduction: Giant Tooth-pick
Is it a bird? Is it a plane no its a... giant tooth-pick????
Yes people its a GIANT tooth-pick?!?!? and ill be showing you how to make it (even though its pretty straight forward)
YOU WILL NEED:
a dowel
a toothpick
a ruler
a pencil
a saw
and sandpaper
YOU WILL NEED:
a dowel
a toothpick
a ruler
a pencil
a saw
and sandpaper
Step 1: Measurements
The first step it to take measurements and decide where to cut your dowel. my tooth-pick was 2 mm in diameter and the dowel was 9mm so the ratio was 1:4.5. my tooth-pick was 66mm long and the tip was 10mm long so the measurements for the Giant tooth-pick came to:
diameter: 9mm
length: 297mm
tip(point at the end): 45mm
diameter: 9mm
length: 297mm
Step 2: The Tip
This step is pretty straight forward just remember not to make the tip too long.
Step 3: Finished!
Now clean your gums!
