Introduction: Giantamax Snorlax Flower Pot
I build a lying-down Snorlax in Fusion 360.
And empty its belly to make it as a flower-pot or a container.
If you put in a tree-like plant, and cover the belly with moss, it will look just like Giantamax Snorlax in Pokemon cartoon.
我使用Fusion 360设计了一个躺着的卡比兽。
并且将它的肚子镂空,使它成为一个花盆或是容器。
如果你放入一颗树状的植物,并用苔藓覆盖肚子,看起来会像动画里的超极巨化卡比兽。
3D Printer
3D 打印机
Files for 3D Printing are below
(Notice,there're two kinds of belly, as shown in the picture above, print the one you need)
以下是3D打印文件
(注意,肚皮有如上图中两种,选择你需要的打印)
Step 1: Notice
The size is shown in the picture, not big for a flower pot.
Just enough for small plants.
I did not put a hole at the bottom, you can add one before printing or drill one after printing if you need.
In this project, you may put different kinds of plants into one flower pot. Please make sure they have similar preference about light, humidity, etc.,so they can all grow well.
尺寸如上图所示,并不大,只能放入较小的植物。
未在底部打孔,如果你需要,可以自行添加。
在这个项目里,你可能会把不同植物放入同一个花盆中,请确认它们有相似的习性,让它们都能健康成长。
Step 2: 3D Print, Paint and Assemble
Print out the parts.
Make up the face and polish the nails.
And assemble the parts. Foot parts need glue to attach to the body.
打印零件。
化妆及美甲。
组装,脚部零件需要用胶水粘到身体。
Step 3: Put in Your Plant
My choice is Syzygium grijsii.
It is small and looks like a tree just as I wish.
Put in your plant and mound with more soil make it look like the belly-shape of Snorlax.
我的选择是小叶赤楠,它较小且看起来像棵树。
放入植物,并用泥巴堆成卡比兽肚皮形状。
Step 4: Cover With Moss
Moss looks like grass in this size.
Cover the soil with moss.
苔藓看起来像缩小比例的草。
用苔藓覆盖泥土表面。
Step 5: Modify
I'm really bad at planting and my balcony is a mess now.
There're still many details to add or fix to make Snorlax look better.
If you made this project, please post a photo of yours in the comments so I can learn from.
我的园艺技术很烂,而且我的阳台现在一团糟。
仍有很多可以添加或修改的细节,让卡比兽看起来好一些。
如果你也做了一个,请在评论区发张图让我参考学习。
