Introduction: Gingerbreadsaurous Rex Cookie
I am trying to get into the holiday spirit so last night my husband said let make some cookies. Oh what fun - so I went digging through my collections of recipes, ingredients and cookie cutters and thought "no cookie says Christmas more than a gingerbread man cookie - right.
All I could find was this T-Rex cookie cutter, so here is my twist on this classic cookie.
Thanks and enjoy
Lisa Ancarrow-Maltby
Tissuepapers
Thanks and enjoy
Tissuepapers
Step 1: My Grandmother's Gingerbread Recipe
Here is my grandmothers gingerbread cookie recipe....shhh it's a secret recipe
Gingersaurous Rex Cookies Recipe
INGREDIENTS
For the cookies
3 1/4 cups sifted all-purpose flour
3/4 teaspoon baking soda
3/4 cup (1 1/2 sticks) unsalted butter (room temperature, softened)
1/2 cup dark-brown sugar, packed
1 Tbsp ground ginger
1 Tbsp ground cinnamon
1/2 teaspoons ground cloves
1/2 teaspoon ground nutmeg
1/4 teaspoon finely ground black pepper
1/2 teaspoon salt
1 large egg
1/2 cup unsulfured molasses
METHOD
1 In a large bowl, sift together flour, baking soda, and spices. Set aside.
2 In an electric mixer fitted with the paddle attachment, cream the butter. Add sugar and beat until fluffy. Mix in eggs and molasses. Gradually add the flour mixture; combine on low speed. (You may need to work it with your hands to incorporate the last bit of flour.) Divide dough in thirds; wrap each third in plastic. Chill for at least 1 hour or overnight. Before rolling out, let sit at room temperature for 5-10 minutes. If after refrigerating the dough feels too soft to roll-out, work in a little more flour.
3 Heat oven to 350�. Place a dough third on a large piece of lightly floured parchment paper or wax paper. Using a rolling pin, roll dough 1/8 inch thick. Refrigerate again for 5-10 minutes to make it easier to cut out the cookies. Use either a cookie cutter or place a stencil over the dough and use a knife to cut into desired shapes. Press raisins, chocolate chips, or candy pieces in the center of each cookie if desired for "buttons".
4 Transfer to ungreased baking sheets. Bake until crisp but not darkened, 8 to 10 minutes. Remove from oven. Let sit a few minutes and then use a metal spatula to transfer cookies to a wire rack to cool completely. Decorate as desired.
Makes 16 5-inch long cookies.
INGREDIENTS
For the cookies
1/2 teaspoon salt
1 large egg
METHOD
Step 2: Roll, Cut and Bake
bake at 350 for about 8-10 minutes or until nice and brown - don't they smell wonderful.
Step 3: Place on a Cooling Rack
before you decorate - place on a wire cooling rack to let the cookie cool.
Step 4: Let Your Imagination Go Wild - Royal Icing Time
let your imagination go wild with the icing
Royal Icing recipe
1 egg white
1/2 teaspoon lemon juice
1 3/4 cup confectioners sugar (powdered sugar)
Royal Icing
The traditional way to make Royal Icing is to beat egg whites and lemon juice together, adding the powdered sugar until the mixture holds stiff peaks. With modern concerns about salmonella from raw eggs, you can either use powdered egg whites or heat the egg whites first to kill any bacteria. With the heating method, mix the egg white and lemon juice with a third of the sugar, heat in a microwave until the mixture's temperature is 160�F. Then remove from microwave, and beat in the remaining sugar until stiff peaks form. Using the powdered egg whites method, combine 1 Tbsp egg white powder with 2 Tbsp water. If the icing is too runny, add more powdered sugar until you get the desired consistency. Fill a piping bag with the icing to pipe out into different shapes. Keep the icing covered while you work with it or it will dry out.
Royal Icing recipe
1 egg white
Royal Icing
