Introduction: Glacier Block
The only difference between the Fire Block and the Ice Block are both the same. The difference is in the color of paints used.
This is a small ice block or piece of a glacier for use in RPGs, war gaming, or miniature gaming. This is a very easy construction. If you have some craft paints and a hot glue gun than the cost will basically be free.
Step 1: What You Will Need
Things you will need:
hot glue gun
craft paint/paint brush
scissors
paper egg carton
mod podge (optional)
Step 2: Cut the Carton
I used the huge 3 dozen eggs container just cut off a piece. Just use a piece that you think will do the trick big or small.
Step 3: Cut Some Cardboard for a Base and Mount It
Use some hot glue to seal up the seams on the bottom. Also drag the glue around a bit to add some texture.
Step 4: Base Paint
Paint the glacier a darker blue and let it dry.
Step 5: Dry Brush
Dry brush a lighter shade of blue and let dry.
Step 6: Dry Brush - 2
Use a heavy-ish coat of white paint to finish it up
Step 7: Mod Podge
Add some mod podge gloss to make it shine like ice.
