Introduction: Glados Bookmark
I made a Glados bookmark for the Books & Bookshelves Contest to get more comfortable with Autodesk Fusion 360. I hope that you all like it! :3
1) Yellow Pre-Wired 0402 SMD LED Pre-soldered Micro 0.1mm Copper Wired HO & N
https://www.temu.com/goods.html?_bg_fs=1&goods_id=601099517473197&_x_sessn_id=7czmbyi34w&refer_page_name=bgt_order_detail&refer_page_id=10045_1713059180176_e1s8sgpa27&refer_page_sn=10045
2) Black Filament
3) White Filament
4) 3D Printer
5) Autodesk Fusion 360 (or any other design software)
6) CR2032 Button Coin Cell Battery Socket Holder Case
https://www.temu.com/goods.html?_bg_fs=1&goods_id=601099533943881&_x_sessn_id=s54bo9n2tf&refer_page_name=bgt_order_detail&refer_page_id=10045_1713063906929_dxlcasojme&refer_page_sn=10045&no_cache_id=4wt03
7) Tape or Copper Foil Tape
https://www.temu.com/goods.html?_bg_fs=1&goods_id=601099535561097&_x_sessn_id=s54bo9n2tf&refer_page_name=bgt_order_detail&refer_page_id=10045_1713068523400_q2k9vc3rmc&refer_page_sn=10045
Step 1:
Go to canvas to open Glados image.
Step 2:
Trace Glados by using line and fit point spline tools in sketch.
Step 3:
In solid, extrude parts individually to a different height, then add a hole for the eye.
Step 4:
Make a sketch onto of Glados's face and trace.
Then, extrude and drag the part to the side.
Step 5:
Go to the bottom to create a sketch and extrude to 1mm.
Create a sketch on top of the extruded part and extrude to 1mm.
Step 6:
3D print parts individually.
Step 7:
Put the two parts together.
Step 8:
You can cut the wires short to fit onto the bookmark.
Attach the wires to the correct color with tape.
Step 9:
Et voilà!
