Introduction: Glass Bead Wire Rings
easy glass bead wire rings
Step 1: Supplies
What you need:
Wire
Glass beads
Jewellery pliers
something circular to shape ring
something to cut wire (wire should be thin enough that scissors work)
Step 2: Choose Bead
step 1:
choose your bead
cut your wire (way longer than you think better to be too long than too short we can use the excess wire later)
place bead in the middle of your wire
Step 3: Loop Wire
part a : ring band
loop wire around until you have the thickness of the ring band you desire
i recommend 2 either side
part b: wrapping around bead
once you have your band ready wrap each end of the wire around half of the bead alternating each time.
repeat until the bead no longer moves or your happy
Step 4: Setting Bead in Place
This part is fiddly but easy and adds to the aesthetic aspect of the ring
With the remaining wire wrap tightly around the band wires.
Repeat on either side as many times as you wish (you may have excess wire so feel free to cut it)
Make sure the ends of the wire are tucked in so they cannot hurt anyone (very important) can be easily done with pliers
Step 5: Adding Final Touches
This isn't necessary however adds to the ring
Wrap any excess wire around the middle of the band
Make sure not to leave any sharp edges that could hurt anybody
Step 6: Complete Ring
Your ring is complete
These are super fun to make and you can get the hang of them very quickly
(the photo above shows some of the first rings I ever made compare them to the ones shown at the start and the improvement is huge)
Thankyou
