Introduction: Glass Bottle Planter
Hi All,
In this instructable, I will share how to cut a glass bottle using a Dremel and make a planter.
This is a recycling project, helps in reducing our wastes and could be used as a gifting idea for coming festive season
Step 1: What Do We Need ?
- Empty wine bottle
- Scrap wood
- Superglue
- Dremel with extension
- Diamond disc 50mm
Step 2: Building the Setup
- For my first version, I made a simple "L" stand and attached Dremel to it as shown
- The bottle would wobble and I could not slide the bottle, for a straight cut
- I had to take inspiration from a typical saw table
- I needed a larger base
- and a sidewall to slide the bottle against it
I found that the best position to cut a glass bottle was to have 3/4" space between the cutting disc and the sidewall
- In my updated version,
- I took a scrap wood piece with 2" height and fixed Dremel on it
- To adjust the space to 3/4", I added few more laminated scrap wood pieces as shown
- For the base, I took a large piece of laminated wooden/MDF plank and clamped it to the sidewall
Step 3: Cutting
- We need to take precautions while cutting the glass bottle
- Use safety glass for eyes, earplugs for ears, a respiratory mask, and gloves
- While cutting the disc must be cooled down using a water siphon
- This also helps to catch glass dust which is a must
- Once the setup is ready, mark reference lines on the bottle
- Gently place the bottle on this jig and start cutting it
- Do not push, let the disc do it's cutting job
- Cut the sides first, then top and base at the last
- depending on the size of the bottle, you may have to elevate the bottle at the top and base to get a crosssection, easiest way is to place another plank below the bottle
Step 4: Wooden Stand
- I used Jigsaw to cut a wooden stand from scrap wood
- I glued the pieces together
- Stained it using diluted acrylic paint
Step 5: Finishing
- The cut bottle edges needed to be sanded using 80 grit for removing any sharp edges
- post which, we need to polish the edge as smooth as possible by sanding by 150, 220, 400, 600, 1000, and finally with 2000 grit
- This takes about 30 minutes and is worth the effort
- Get some soil and succulents and plant it
- Admire your work and cut some for your neighbors too and gift them
