Glass Insulator Lamp
2,376
35
4
Introduction: Glass Insulator Lamp
It has been a while since I picked up, an aged wooden tripod from a neighbor’s
pile of neglected items. Some time ago I was glad to receive a glass electrical insulator as a gift from a colleague of mine and there was no much later from both events that I came up with the idea to combine those two into a vintage lamp.
Step 1: The Materials
Luckily enough there was no need to purchase any consumables needed to
construct the lamp. The tripod was missing its top part. Therefore I decided to construct a new one. The new top was made from an iron part and three wooden parts (marine plywood). I rubbed and polished the new part using wood varnish. I used black mat paint for the metal parts.
Unfortunately I did not take many pictures of this procedure.
Step 2: The Mounting
The hole in the glass electrical insulator was way too wide than needed to
be firmly lean on the construction. In order to get it narrowed I used chemical fixing resin with Μ10 long nuts and I managed to firmly place the insulator on top of the tripod using as base an Μ10 long screw.
Step 3: The Novel Led Panel
I was planning my lamp would have an evenly emitted light that was the
reason why I picked led lights and an unused compact disk. I placed evenly distributed led panel strips on the compact disk and connected the panel to a 12V Power supply using a vintage cable cord. A marine plywood disk placed underneath the CD made the cod less visible.
In order to keep the led strips cool and avoid overheating on the panel, I plan to replace the CD with aluminum.
Step 4: All Together
As soon as I had each of the parts completed I started to put them
together into my new vintage lamp.
Hopefully you’ll fancy the lamp as much as me and my wife did.
Lights Contest 2017
Lights Contest 2017
Before and After Contest 2017
1 Person Made This Project!
  • For the Home Contest
  • Make It Bridge
    Make It Bridge
  • Big and Small Contest
4 Comments
VernonP1
VernonP1
5 years ago
great work!!!!!! is there a reason you brought the 12v lead down from the outside of the CD and not the inside?
fra
fra
Reply 5 years ago
Thanks! The other side had a label and from this side the light has better reflection.
VernonP1
VernonP1
5 years ago
great work !!!!
Abelos
Abelos
5 years ago
Amazing!!!
