Introduction: Glass Like Finish on Wood
Hey I'm Batmantwo and I'm a 15 year old who loves making things so here's my instrutable
This is a nice way of finishing if you project with a professional look and feel
It's also fairly cheap to do
Step 1: Sanding Your Wood
This is one of the most important steps in this whole project. I started with 120 and went through all the grits to 1000 you can go higher I probably would if I did it again make sure you sand the whole project that you want to have the glass finish
Step 2: Cleaning the Wood
Clean the wood so there's no more dust or anything on it. Make sure there isn't any scratches in the wood because you won't be able to get rid of them Once you have finished the wood
Step 3: Set Up for the Epoxy
Place the wood on another piece of scrap wood and place a plastic back under it to stop the over spill from gluing something else
Mix up the epoxy in a cup and try not to add bubbles to this to make it easier later
Step 4: Pour the Epoxy
Pouring the epoxy isn't easy you have to find the perfect height to pour the epoxy from not to high or you add bubbles and not to low or you touch the product and add fingerprint. Take a paint brush and push the epoxy to all the corners of the wood and down the sides once your happy with the consistency of the epoxy than leave in for twenty minutes after the twenty minutes come back and use a blow torch and pop the bubbles when doing this don't stay in one spot for to long or it will Cook the epoxy just a quick wavey movement over it than leave it for twenty four hours to set
Step 5: Repeat Step 4 If Needed
If needed repeats step 4 to get a higher shine on the wood do a little sanding with the highest grit sandpaper and just knock off the high spots then repeat step four
Step 6: Polish the Piece
Use some plastic polish and a rag to wipe on the polish and then buff it off with the rag
