Introduction: Glow in Dark Decor
Decorating my room is something that I really enjoy. So, I decided to make something that is beautiful to look at and at the same time something more useful. This is a hanging decor that glows itself when it's dark. It is really simple to make and surely adds aesthetic look to your wall. Let's learn to make it.
Step 1: Collect Materials
To make this Decor, you'll need :
- Drawing sheet ( I used A4 sized ivory sheets for a better look .)
- Water colors and paint brushes
- Cardboard
- Breadboard
- Arduino UNO board
- Different color Light Emitting Diodes (LEDs)
- 10 k ohm carbon resistor
- Light Dependent Resistor (LDR)
- Connecting wires
- Adhesive
Step 2: Making the Base
Take a sheet of any size you want. While choosing the sheet,keep in mind that you have to paint this sheet with colors. I've used a white ivory sheet.
- Using paint brush,apply a layer of water on the sheet.
- Once the upper surface of the sheet is wet, start applying color from the top of the sheet.
- Successively, use another color. This gives a gradient effect.
- Using a black marker, write what you want. You can also draw something you like.
Step 3:
Take a cardboard of the same size as your sheet and paste the sheet on the cardboard.
Step 4: Connecting LEDs
- Start placing your LEDs by piercing through the cardboard.
- Connect the positive terminal (longer leg) of one LED with the positive terminal of the next with the help of connecting wire. Connect all the positive terminals.
- Similarly, connect all the negative terminals. Make sure that the wire connecting positive terminals does not touch the wire connecting negative terminals. Use insulation tape to separate the two wires.
- Leave some extra wire at the last LED. This extra wire will go to breadboard.
Step 5: Circuit
- Connect positive terminal of LED connection to pin 7 of Arduino.
- Connect the negative terminal of the LED connection to GND pin of Arduino.
- Place the two legs of LDR on breadboard. Connect one leg of LDR to pin A0 of Arduino.
- Connect one leg of 10k ohm resistor to the the same leg of LDR .
- Connect the other leg of 10k ohm resistor to GND terminal of Arduino.
- Now, connect the other leg of LDR to 5V pin of Arduino.
Connections are done!
Fix the breadboard and Arduino on the back of cardboard.
Step 6: Code
This is the code.
//Code for making LEDs glow in the dark
int ledPin =7;
int ldrPin= A0;
void setup()
Serial.begin(9600);
pinMode(ledPin,OUTPUT); //Using digital pin 7 for generating output
pinMode(ldrPin,INPUT); //Using Analog pin A0 for getting input
//The circuit will now take the values from LDR to detect darkness and LED will act depending on LDR value
void loop()
int ldrValue=analogRead(ldrPin);
if (ldrValue<=100)
{digitalWrite(ledPin,HIGH);
else {
digitalWrite(ledPin,LOW);
Serial.println(ldrValue);
Upload the code to Arduino using USB cable.
Step 7: Making Frame
- Take a black sheet of length same as that of the sheet and divide it into four parts of width 1 cm, 2 cm, 1 cm and 2 cm respectively.
- Fold the sheet along the lines drawn to form a cuboid.
- Make four such cuboids.
Paste two of the cuboids vertically on the base along the edges.
Paste the other two cuboids horizontally.
Add a hook at the back to make it hanging .
Step 8: Connecting to Power
You can supply power to your Arduino by a DC battery.
Connect your Arduino to a DC battery using Power jack.
Before connecting to a battery you should test the circuit right after uploading the code to Arduino i.e., using the laptop/computer itself via USB cable.
And you are ready to rock!
