Introduction: Glow in the Dark Letter Pendant
Hello everyone, today I bring you a tutorial to make an original glow-in-the-dark necklace.
Hola a todos, hoy os traigo un tutorial para hacer un collar original que brilla en la oscuridad.
- UV resin
- Letter and circle molds
- Silicone cups and sticks
- Fluorescent powder
- Sand
- Chain, hitch and pliers
- Resina UV
- Moldes de letras y de círculos
- Vasitos de silicona y palillos
- Polvo fluorescente
- Arena
- Cadena, enganche y alicates
Step 1: Letter
Mix some resin with the glow-in-the-dark powder, then fill the letter we want and put it in the UV light lamp. When the resin is dry we remove the lettering from the mold.
Mezclar un poco de resina con el polvo que brilla en la oscuridad, después llenar la letra que queremos y ponerlo en la lámpara de luz UV. Cuando la resina esté seca sacamos la letra del molde.
Step 2: Base
Pour a thin layer of transparent UV resin and put it under the lamp. Then, make a mixture of resin and sand, pour into the mold and put the letter, now we will put it under the lamp and it will dry.
Echar una capa fina de resina UV transparente y ponerlo debajo de la lámpara. Después, hacer una mezcla de resina y arena, echar en el molde y poner la letra, ahora lo pondremos debajo de la lámpara y se secará.
Step 3: Fill
Fill until the resin covers the lettering and dry again in the lamp.
Rellenamos hasta que la resina cubra la letra y volvemos a secar en la lámpara.
Step 4: Finishing
Remove from the mold and attach the hitch and chain.
Sacar del molde y ponerle el enganche y la cadena.
Step 5:
You can make the designs you want and use them for different things, I chose the sand in the base to make the letter stand out more, but I want to show you how to do it with a beach theme.
We have to start making the letter we want, in the same way as before (the color we want). Fill the circle with transparent resin and dry it in the lamp. When it is dry we paint the beach with a gradient leaving space for the sand and pour the mixture of sand and resin as if it were the shore of the beach. We dry it in the lamp and paint the waves with white acrylic paint. When it is dry we put the letter, fill with transparent resin and dry in the lamp.
Puedes hacer los diseños que quieras y usarlos para diferentes cosas, elegí la arena en la base para que la letra resaltara mas, pero os quiero enseñar la forma de hacerlo con temática de playa.
Hay que empezar hacer la letra que queramos, de la misma manera que antes (del color que queramos). Rellenamos el círculo con resina transparente y lo secamos en la lámpara. Cuando esté seco pintamos la playa con un degradado dejando espacio para la arena y echamos la mezcla de arena y resina como si fuera la orilla de la playa. Lo secamos en la lámpara y pintamos las olas con pintura acrílica blanca. Cuando esté seco ponemos la letra, rellenamos con resina transparente y secamos en la lámpara.
Step 6:
I also made fridge magnets with other designs. To put the magnet on, you glue it with glue on the back. I hope you liked it, thanks for reading!
También hice imanes para el frigorífico con otros diseños. Para poner el imán, se pega con pegamento en la parte de atrás. Espero que os haya gustado, gracias por leerme!
