Introduction: Glowing Fitzroy Storm Glass
The Fitzroy Storm Glass is a weather instrument that became popular in the 1860's for predicting the weather. It is a sealed glass vial that contains chemicals that crystallize in various formations depending on changes in the weather. Admiral Fitzroy, Captain of the HMS Beagle, conducted a study and perfected the formula during the years of 1831 to 1836. The exact origin of the instrument is unknown and believed to have been invented around the 1700's. Because the instrument is somewhat fragile, I wanted to make something that would allow hanging on a wall and safely illuminate for observation. The hanger is made to prevent the storm glass from tipping over. White leds with a variable dimmer using a LM317 are used for illumination. I got the storm glass from Klockit
Step 1: General Layout
The parts for the wooden hanger is made from 1/2 inch hardwood plywood. Three pieces are used. A back plate, base shelf and a piece midway to stabilize the tube on the base.
Step 2: Base and Shelf
Two pieces are used for the base and shelf. All 1/2 inch hardwood plywood. The base has a portion bored out to hold the base of the storm glass. I used a 2 inch hole saw to bore half-way down then a 1-1/2 inch flat spade bit to take out more area. A screw driver or chisel can be used to clean out the rest. The top shelf, uses a 1 inch bore saw to make the hole.
Step 3: Holes for Leds
Drill 3 holes in the base for the leds. Wire the leds in parallel and attach a paired lead to run to the led dimmer. Use hot melt glue to hold leds and connections underneath the base.
Step 4: Back Panel Holes
Four holes need to be drilled on the back plate to mount the base and shelf. Use 1-1/4 flat head screws and pre-drill holes slightly smaller than the screw's diameter to prevent the wood from splitting. Countersink the holes to keep the screws flush on the back. Attach a screw, then carefully square-up the assembly before attaching the second screw. This will allow accurate and square placement of each piece.
Step 5: LED Controller
I used a LM317 regulator to control the brightness of the leds. The controller is helpful when photographing crystal growth. The wide range of contrast, makes photographing the crystals a challenge. The controller was built with a plastic box with a two-conductor cable connecting to the storm glass holder. A 9 to 12 volt wall-wort style power supply was used for power. Current can be adjusted from 1 to 20 milliamps for the leds. Series operation of the leds is possible, but will require at least 15 volts for the power source. The balance between the leds seems to be fine when running in parallel. Follow the schematic and build the circuit on perf-board and place inside a suitable box.
Step 6: Schematic
The parts in the schematic are not super critical. The values for R1 and R2 set the brightness. The capacitor C1 can be any value from 10uf to 1000uf as long as the rated voltage is higher than the power supply. Using connectors for J1 and J2 makes it easier to build. Use what you have.
Step 7: Crystal Growth
I made a movie of the crystal growth before I started making the holder. Having a controlled lighting source such as this, would have been helpful.
Step 8: Conclusions
Different woods could be used for the holder. Lowes had some red oak 4" x 2' x 1/2 inch thick hobby boards for less that $4. I used the plywood because I had some left over from an earlier project. You can apply a stain and finish to complete the project.
Admiral Fitzroy made these observations as regards to predicting the weather:
From http://en.wikipedia.org/wiki/Storm_glass
The formula is also mentioned at the above site.
If the liquid in the glass is clear, the weather will be bright and clear.
If the liquid is cloudy, the weather will be cloudy as well, perhaps with precipitation.
If there are small dots in the liquid, humid or foggy weather can be expected.
A cloudy glass with small stars indicates thunderstorms.
If the liquid contains small stars on sunny winter days, then snow is coming.
If there are large flakes throughout the liquid, it will be overcast in temperate seasons or snowy in the winter.
If there are crystals at the bottom, this indicates frost.
If there are threads near the top, it will be windy.
Over the weeks I have been observing the changes of the crystals along with the weather. The wider the temperature changes are, the more changes I see in the crystal growth. If the temperature drops rapidly, crystals will start to snow inside the glass. Placing the storm glass outside in a protected porch would show the most effects from the ambient weather. Can you predict the weather with this device? Perhaps, but I would still check with weather reports on TV or the internet.
