Introduction: GoPro Wrist Mount
In need of a Wrist Mount for your GoPro Hero 3? Look no further! Following this guide, brought to you by ArcticUnion.com, you can make your own - unless you threw away the box.
THINGS YOU WILL NEED:
1 - GoPro Box
1 - Strap of some kind, preferably with a buckle
1 - Needle and Thread
1 - Heat gun
1 - Wrist
Step 1: RIP
Remove the square, GoPro mount from the top of the original packaging.
Step 2: CUT
Carefully cut the square into a rectangular strip.
Step 3: BEND
Using a heat gun, bend the two short ends of your perfectly cut rectangle. (Protip: Any $13 heat gun from your local hardware store will suffice.)
Step 4: HOLES
Cut holes in either end with a width that corresponds to that of your chosen strap.
Step 5: SEW
Push the ends of your strap through the newly-made holes, and then sew them securely into a loop on each end.
