Introduction: GoT Wire Inlay
You'll need! An image of your choice!
1. Wood
2. wire
3. Something to indent the wood (router or flathead screwdriver)
4. Small hammer
5. Sand paper
6. And a finish!
1. Wood
2. wire
4. Small hammer
5. Sand paper
6. And a finish!
Step 1: Choosing Your Image
Choose your image and either print it off the internet, should use a sillhoutte, it's easier that way.
Step 2: Choose You Wood
Choose a piece of wood i used a thicker wood because i didnt trust myself that much haha
Step 3: Wire
You can use buy flat wire or just buy any size wire and flatten it with a hammer
Step 4: Copying Your Image on Wood
Copy your image to the wood, make sure your image is visible!
Step 5: Indenting in the Wood
You can either use a very thin flat head screwdriver and a hammer or a router
Step 6: Putting Your Metal In
After you finish indenting you need to start adding the metal, bend the metal to fit in your slots, hammer lightly in then super glue it in
Step 7: Sanding
After your done putting the metal in wait for the super glue to dry, start with a low grit sand paper, and start to go up
Step 8: Finish
Finish by adding laquer or whatever you choose! I used a bit of fire to add the brow color to it, sanding was cool to see the silver color come out!
