Introduction: God's Eye Lamp
About: Hi everyone! When I met this website I didn't doubt to register to start sharing, commenting, learning and participating. I hope you like my publications! You guys are great!
I present you the god's eye lamp, there are many ways to make it, many colors, sizes and designs, I hope you like this tutorial.
Os presento la lámpara ojo de dios, hay muchas maneras de hacerla, de muchos colores, tamaños y diseños, espero que os guste este tutorial.
  • Threads
  • Sticks
  • Pliers
  • Silicone
  • Scissors
  • Hilos
  • Palos
  • Alicates
  • Silicona
  • Tijeras
Step 1: Cross
Glue two sticks parallel to each other with silicone, I used two parallel lines on a piece of paper. I made 4 crosses but in the end my lamp was 3.
Pega dos palos de forma paralela con silicona, yo me ayudé de dos líneas paralelas en un papel. Hice 4 cruces pero al final mi lámpara fue de 3.
Step 2: Securing the Center
Secure the joint with thread, wrapping it around the two diagonals.
Asegura la unión con hilo, dándole vueltas en las dos diagonales.
Step 3: Twist and Turn
Start with the square, there is only one thing to do: go over the stick, flip it underneath, move to the next stick and do the same.
Empieza con el cuadrado, solo hay una cosa que hacer: pasar por encima del palo, darle la vuelta por debajo, pasar al siguiente palo y hacer lo mismo.
Step 4: Ensures
Tie knots at the back and secure with silicone.
Hacer nudos por detrás y asegurarlo con silicona
Step 5: Repeat With the Other Colors
I am leaving spaces between the threads to let the light pass through. Make three, four or five more.
Estoy dejando espacios entre los hilos para dejar pasar la luz. Haz tres, cuatro o cinco más.
Step 6: Three, Four or Five
Tie a few knots to join all the pieces together. You can make three of the same, four or five. With three you will make an open triangular prism. With four an open cube. And with five a cube closed on one side.
Haz unos nudos para unir todas las piezas. Puedes hacer tres iguales, cuatro o cinco. Con tres harás un prisma triangular abierto. Con cuatro un cubo abierto. Y con cinco un cubo cerrado por un lado
Step 7: Hang
I tucked in some threads to make the hanger, in other lamps it may be different. It can also be put on a table lamp.
Metí unos hilos para hacer el colgador, en otras lámparas puede ser diferente. También se puede poner en una lámpara de mesa.
