Introduction: Going Merry Chopper Boat From One Piece
About: Mostly into trains, diy, electronics, computer science you can see my work on
This boat is from One Piece. It's the Going Merry with a special "Chopper" sail.
The original design is from Haaland and published on Maker World.
Without explanations and missing parts and printing optimization requirements, it needed a remix I made and this page to help you build it.
In addition, I've designed a cool facehead and a boat plate published as remixes here.
The remix I've made with all these changes is published here, including missing parts, print optimization, hours of time saved, new parts, and naming.
You'll find the parts for printing this here.
Enjoy
A 3D printer printer. Best multicolor one such as the Bambulab A1 or A1 mini.
PLA filament, multiple colors
Plastic glue such as UHU plast
Pliers
Clamps
Step 1: Boat Hull, the Body
You need to print or have printed the plates named "boat hull #2" and "boat hull #4"
You need to glue the 3 pieces. Their base is flat, so you need a flat place to work on. You have just to align them.
Step 2: The Rear Deck
You need to print or have printed the plate named "boat hull #3".
Slide the rear deck into the cabin hole and glue them.
Step 3: Canon Holes
You need to print or have printed the plate named "Windows and Doors". It should have been done in step "canon holes".
Place and glue the canon windows as shown.
Step 4: Rear Canons
You need to print or have printed the plate named "hardware"
You need to adjust the two rear canons. They are quite hard to glue. I used a plier to stabilize them.
Don't glue the cabin before adding the canons :-)
Step 5: Cabin Decorator
You need to print or have printed the plate named "cabin decorator" and add it to the cabin. The little piece at the bottom right on the picture is a stair.
Step 6: Add the Cabin to the Boat Hull
Add the cabin to the boat hull. You can use stairs to align the parts. It's important to have the rear canons in place before closing the rear deck.
Step 7: Doors and Windows
Doors will fit perfectly into the holes. You need to take care of windows, as they are not all the same size and height.
The two very small windows are for the left side of the cabin.
The two small, a little more thick, are for the right side of the cabin.
The two big ones are for the rear deck.
Glue all of them
Step 8: Prepare the Rear Railing
You need to print or have printed the plate "Decorations 2" and the plate "Mast Hardware".
Glue the pulleys into the railing.
Step 9: The Side "T" Decorators
You need to print or have printed the plate named "Decorations 1".
You need to carefully adjust this piece before glueing.
Step 10: The Bow Decorator
You need to print or have printed the plate named "Decorations 2" and glue the front bow decorator.
Step 11: The Front Canon
Use the same tips for the front canon as described in step 4.
Step 12: The Front Deck and Front Rail
You need the front boat hull from plate "boat hull #2" and the front rail from plate "decorations 1"
They need to be glued at the same time to the boat hull.
Step 13: Horizontal Decorators
You need to glue the horizontal decorators on the left and right sides. These parts are from the plate named "Decorations 2"
Step 14: Edges
You need to print or have printed the plate named "edges."
The side edges should be glued and tightened appropriately.
Step 15: The Last Rear Vertical Decorators
These decorators are from a plate named "decorations 1". Edges should help you adjust them.
Step 16: The Boat Hull
The boat hull is on a plate named "boat hull #1". Be careful when gluing to adjust it. I used the rear view for that.
Step 17: The Below Decorator
This decorator is from the plate named "decorations 1". It has to be glued below, under the boat hull, in an appropriate way to let it stay in place :-)
Step 18: The Decoration Balls
The four decoration balls are from a plate named "Decorations 2". You probably have to prepare them as shown.
Beware of your fingers !
Use the picture to see how to put them together and glue them.
Step 19: The Rear Rail
The rear rail is from the plate named "Decorations 2".
Place the rail and glue it. Don't forget to use clamps.
In the last photo, you can see a mast. It was just a test; don't put it here right now...
Step 20: The Back Decorator
The back decorator is from the plate named "decorations 1". It has to be fixed as shown.
Step 21: Stair Rails and Railings
These parts are from plates named "decorations 1" and "decorations 2"
They are glued as shown, first the railings, then the stairs.
Step 22: The "Going Merry" Boat Name
This is new to the original design. I saw a big, rectangular hole below. I had the idea of building a plate with the boat name.
It has to be printed with a better precision, for example, 0.12 mm.
It should fit into the hole and need to be glued.
Step 23: The Rudder Support
This support has to be glued just below the boat name plate. It's from a plate named "hardware"
Step 24: Main Mast Preparation
The attachment system for the main mast is a rectangle. You need to put the mast on without glueing it, test the crossbar attachment, and then glue this part to the mast.
The mainmast is from the plate named "mainmast," and the attachment is from the plate named "hardware".
Step 25: Main Mast Preparation, the Lookout
You need to glue the lookout to the upper main mast. Both parts are from "boat hull #1" and "lookout" plates.
Step 26: The White Sail
The sail has to be printed. If you want this logo, you have to print it on the "chopper logo" plate.
The sail is from the "White Sail" plate.
I never saw a "Going Merry" with a chopper sail. This was from the original design.
Step 27: Main Mast, the Front One for the White Sail
The black parts are from the plate named "Mast Hardware". The hooks are of different sizes.
You'll probably have to sand or use the blue tool to allow these parts to fit as shown.
Beware of this tool! I had to go to the hospital for strong hand surgery in the past. Please take care!
Put the small hook first, then the medium-sized one, and then the bigger one.
You only need to glue the lookout to the black attachment system.
You need to attach the sail before putting it in place on the boat and gluing it.
Step 28: The Rear Mast and the Red and White Sail
This is the last sail, the rear one in red and white. It is really beautiful.
You have to print the sail from the plate named "rear sail" and the rear mast from the plate named "rear mast."
The black parts are from the plate "Mast Hardware."
Pay attention to the mast and don't use force to put the hooks in; the mast can break easily.
To attach the sail, put it vertically as shown.
You can now put the mast on the boat!
Step 29: The Rudder
The rudder is made of two parts. One is the rudder itself from the plate named "boat hull #1," and the other is the other is the surround from the plate named "hardware."
Glue them both together. Adjust the rudder and place it on the boat as shown.
Step 30: The Figurehead
The original figurehead was blank. I made a new one with the face drawn on it.
You have to print the figurehead at 0.12 mm.
The blank figurehead is from the plate named "original head." The one with the face drawn on it is from the plate "new figurehead," and the horns are from the "horns" plate.
Step 31: The Anchor
The anchor is from the "hardware" plate.
The little round piece needed is also from this plate.
Gluing them is a bit challenging, as you can see.
Step 32: Final Parts
There is mount available
I'm working on a mandarin tree as a derivative of this design, coming soon.
Stay tuned, enjoy this boat, and take care of you.
