Introduction: Goldeneye 007 Remote Mine Prop
How to build a functional movie prop "Remote Mine"
(If you can't find the parts to make your own, as a few are hard to track down, head over to my other project where you can 3D print the parts instead:
https://www.instructables.com/id/3D-printed-Goldeneye-007-Remote-Mine-With-beeper-/ )
If you remember the way it feels to sit 2 feet away from your mothers TV, with all your friends jamming on the "C" buttons, and joysticks of your favorite N64 controller, then this is the Instructable for you!
Goldeneye 64, a legendary FPS that set the standards for games of its type for years to come. With both single and multiplayer modes that included a slew of guns, characters and environments this was the game that would be dreamed about by every tweenage boy all through math class. (And social studies, english, history, etc)
Out of any weapon in the game, the one that stands out in my mind the most is the "Remote Mine".
Throw it, and jam the "Z" and "A" button at the same time to detonate in mid air! Now how sweet is that?
Well I threw the dust cover off of my N64 the other week, and was inspired. It has been quite a while since Ive worked on a little project, and followed through, so I figured hey why not make a remote mine prop?
I started with some research, The actual movie prop is made from an old joystick. Either a PC Commander, or a Saitek. It took some doing to track one of these bad boys down, so all in all finding this most-important component will be your hardest task. Consider this an instructable with a dash of scavenger hunt!
Ready to start? Grab your "PP7" and credit card and lets go!
Step 1: Gather Up Components
Here is a list of the things you will need. Some can be substituted so don't get to distressed if you can't find the EXACT components listed below:
-5mm red LED Assembly (Radio Shack)
-"SPST" Push-on/Push-off switch (Radio Shack #275-011A)
-PC Commander or Saitek joystick (Ebay, garage sale, Craigslist)
-Mini-6-LED Chaser circuit (It comes as a kit so get your soldering iron handy)
-Primer/Green/Gray spray paint
-8mm drill bit (Roughly)
-Electrical tape
-Small electronic buzzer/ beeper (optional/ pick a beep you like)
-Hand full of magnets (Size and strength up to you)
-9V battery
-Styrene sheet (or other hard thin material)
The more specific components have been photographed below:
Step 2: Prep First Component
Grab your newly acquired joystick, and a smallish phillips head screw driver, and dig in! Start with just the 4 screws on the bottom of the joystick that ARE NOT ON THE LITTLE FEET! You don't need to take them out until later.
Once you've got this bad boy open, start tearing her guts out with what ever you have on hand. I used a pair of pliers, because I became impatient when the baby screws inside began stripping.
Step 3: Place Lower/upper Halves Back Together
Its really up to you but the rubber feet and blue switches here can be taken out, or left in. I took them out. On the actual prop they are removed and the holes filled in before painting.
Step 4: Choose Your Paint!
Well I know normally painting doesn't come till the end. But as I said before, I'm very impatient... SO! I decided to paint her up!
Here is your choice. In the movie, the top half of the mine is actually green! I never knew this before I saw an up-close shot of the movie prop. While in the game its ALL gray.
Being a fan of the game first before the movie, I have decided to go with two shades of gray for the mine, instead of the traditional green.
Step 5: Drill Holes for LEDs
For this step I used a ruler to measure from the center hole to the sides of the mine to find where I wanted to place the LED's Then, I used a circle template and drew a circle to the holes could be drilled evenly, and uniformly.
I drilled my holes at around 8mm diameter. But a little filing was required so the LED bezels would snap into place nicely.
Once that was done, I gave the top half another quick coat of paint.
Step 6: Button, and Button-plate
So now you have your mine, with holes drilled for the LEDs!
But how to activate it... Well you probably don't have your detonator watch on, so lets arm them like Pierce does in the movie. With the big red button. Because the hole is a little larger in diameter than the button, and there is no where to mount it, a "Special" styrene sheet mounting board was created. Holes were measured out, and then drilled so I could use the existing mounting points on the underside of the upper body half. Once the holes were drilled the button was screwed into place, and screws screwed into screw holes. Yes, many screws in one sentence.
Make sure to spray paint the top of the assembly before putting it together or you will see the white styrene once it is installed!
As a side note I have seen a few different buttons used for this device. So you don't need to use the standard red cover that comes with this one.
(Any semi-rigid or rigid material will work for the button plate, just make sure its thin enough to fit inside the body without taking up much room)
Step 7: Install LEDs
Next up is to mount the LEDs into the body.
Grab all your LEDs and either feed the wire through the hole, or take the bezel off, insert it into the hole, and pop the LED back up through it.
The LED's themselves are 5mm diameter while the bezels are around 8mm.
One thing I noticed is that the LEDs stick up a little to tall for my liking, so I put the bezel in place first, then pressed them up into the bezel so they did not protrude to far out. I'll leave that up to you.
The great thing about these bezels is that they are pressure fit so they can be taken out and readjusted if need be.
Step 8: Wire Up Circuitry!
So I wont bother giving you instructions on how to build the circuit... only how to modify it once its built. Having a lot of soldering experience, but no circuitry experience, it was a lot of fun to build this kit!
Make sure not to open the kit until your ready to work... I did on the subway and guess what, I had to buy another kit because I lost the ENTIRE BOARD!!!
UPDATE: This morning I was sitting on my couch reading, and I hear something small being pushed around under the couch by my cat. And guess what it was!? The missing circuit board!!! So now I have TWO sets of LED Chasers!
(This happened after I finished the project so If it improves the design I will make sure to add alternative instructions after I experiments a little more on this unit!)
Just to make sure I actually built it right, I only used the components it came with (i.e. I did not install the larger LED's that we installed into the housing in the last step, but instead used the very tiny LEDs included in the kit)
The one thing I did add to this circuit was a little beeper, just to see if it worked or not... which it did. So if you do know what your doing, don't bother installing the LEDs that came with the kit, seeing as they will need to be de-soldered at a later stage.
Check out the video below to see how the circuit should work (And optionally, should sound when its all wired up properly)
Step 9: Wiring to Mine LED's
Although in the last step I shower the circuit chasing all 6 lights in a linear pattern... Somewhere I ran into a problem that sort of messed things up...and I couldn't fix them, so I worked with what I had and changed the pattern. Lights still light up and chase, but its semi-circular on the mine, instead of making a complete circle.
In fact I am very happy with the pattern I got stuck with!!!
Step 10: Glue on Magnets
Next step was so re attach the bottom plate, and glue on some magnets. Now while these are not exactly "Super strong rare earth magnets", they may be from a fridge door... which means they are good enough for me.
As an alternative, you can always unscrew the section I glued over, and insert stronger, smaller magnets INSIDE the housing.
Step 11: YOUR PRETTY MUCH JAMES BOND!
That is it! You are done! The next step is to impress all your friends! Check out the video below to see the mine in action:
30 Comments
2 years ago
Hi there I know it was a long time ago when you built this but I don't suppose you know the voltage of the 5mm Red LEDs that you bought from radio shack. I tried searching radio shack and they do not sell that specific L.E.D any more and the velleman chaser kit doesn't state the voltage of the small L.E.Ds supplied.
Question 3 years ago
How is the on/off switch wired into this thing? It looks like the red wire from the battery is soldered to the switch only and the black wire to the board only. Is there an instruction I missed or is that right?
Answer 3 years ago
To be completely honest I don’t remember!
I did make a newer one a year or so after this. You may find more details there: https://www.thingiverse.com/thing:54528
7 years ago
This is so cool, I actually designed the original Saitek joystick when I worked for them back in the 90's, so cool to see you guys re-creating the mines :-)
Reply 7 years ago
So cool! I love the 3d printer. Yeah I would love to see any material you have on it. Its always interesting to see the process behind the finished piece.
Reply 7 years ago
That is so awesome! I am a product designer myself! (Working on kitchen gadgets/housewares). I would die to see original sketches or drawings for that joystick! Took me quite a while to find this joystick to purchase, they are quite rare!
Reply 7 years ago
Next time I'm looking in my archives I'll see if I can find any sketches, might even have the original CAD although it will probably be in 3D Studio R3....it was the '90's. Cool that you're a product designer too. This is the business I run now - http://www.productresolutions.com/
Think i'm going to have to watch that movie again now!
7 years ago
Ah yes! Ok, so just wire it anywhere between the battery, and the main circuit. on either positive or negative leads. This will let you break the circuit when the button is turned "off"
8 years ago on Step 5
I am currently in the process of making this prop, and I have one question. How should I go about drilling the holes without cracking the plastic?
Reply 8 years ago on Step 5
I actually just drilled it very slowly, I think maybe I drilled a very small pilot hole first, then did t again with the full size, just apply VERY gentle pressure with a full size bit on a very high speed.
Thank you so much for the advice :)
9 years ago
This is amazing!! It's sad how much shapeways charges for the 3D prints. I'd be shelling out almost enough money to buy a printer!
11 years ago on Introduction
Current Radio Shack part numbers:
RadioShack® Red LED with Holder
Catalog #: 276-011
SPST Push On-Push Off Switch
Catalog #: 275-011
Reply 11 years ago on Introduction
Thanks for the details! I bet one could even make a pre made ready-to-buy list on amazon or something? That way one click, and you have all the components.
Most of the electronics parts are at Radio Shack, so you can order there. The only thing they don't carry is the Velleman mini-LED chaser, but lots of places have it on the web.
One more Radio Shack part is the piezo beeper, as far as I can tell it's one of these two:
90dB Piezo Pulse
Catalog #: 273-066
or
76dB Piezo Buzzer
Catalog #: 273-059
And to be complete, the LED kit is: Velleman MK173
Love the prop but I preferred proximity mines in that game. I would throw them all over the place and usually forget where I put them and walk into a few myself but it was fun the see people get annoyed because they couldn't walk anywhere without setting off a chain reaction of explosions through the entire level.
Haha, my favorite was when you spawned and them BLAM! you die due to proxy mines being planted on EVERY spawn zone hahaha.
Brings a tear to my eye remembering those mines.
I just completed mine, its great! i attached an image of mine to this comment, hopefully it works. I wetn with the green from the film.
AWESOME! Seriously I love the remote mine from Goldeneye and I am very happy that you finished your very own!!!!
