Introduction: Golf How to Hit a Drive Long
In golf, a drive refers to the long-distance shot played by the golfer from the tee box. The golfer’s main goal then is to move the ball over a great distance from the tee box, then down the fairway and finally toward the green. The importance in golf how to hit a drive cannot be overemphasized. Golfers can significantly shorten the longer holes on the course, thus, increasing their chances for good scores and their probabilities for winning the tournament
Step 1: #1 Use the Appropriate Equipment
Aside from the proper stance from the address to the follow through, the golfer should have the proper equipment including the right golfing gloves as well as the right drivers such as the 9 and 10 degree drivers.
Step 2: #2 Apply the Proper Grip and Grip Pressure
The type of golf grip used by the golfer largely depends on his personal preference so you may prefer an overhand grip but your competitor may prefer an interlocking grip. This is acceptable for as long as the grip pressure is of the right degree.
Think of the grip as holding a small baby bird in your hand, a technique espoused by Sam Snead – neither too tight as to suffocate the bird nor not too light as to set it free. On a scale of 1 to 10 with 1 being the lightest grip and 10 being the tightest grip, professional golfers apply a grip pressure between 2 and 4 for the perfect release.
Arnold Palmer also recommends applying the most grip pressure on the last three fingers of the left hand while the ring and middle fingers of the right hand perform the same job. In golf, the grip pressure can spell the difference between hitting the ball with ease yet achieving great distance and hitting the ball with tension and yet achieving a shorter distance.
Step 3: #3 Adopt the Proper Body Posture
In golf how to hit a drive also means adopting the proper body posture at address as well as placing the ball in the right position for the driver. Our tips on these matters:
• Your body from your eyes, shoulders and forearms to your hips, knees and feet should be positioned parallel to the target line to ensure proper alignment. Your body must bend at the hips so that your spine is in a straight line – no bending in its middle – while your knees should be slightly flexed.
• Your feet should be just a bit shoulder-width apart; approximately two inches wider is the recommended measurement.
• Your weight should be balanced on the balls of your feet instead of on your toes or heels. The more balanced your stance, the more your swing will be on the correct swing path.
Such position at address will increase the chances for hitting the ball at distances of 300 yards of more when applied simultaneously with the correct swing from the downswing to the follow through.
Step 4: # 4 Make the Swing
Professional golf instructors and players suggest the following tips for the swing itself.
• Adopt a relaxed approach at the start of the downswing, which will build up speed as the club accelerates toward the ball.
• Stay flat. The driving wood should ideally stay on the ground for 25% of the overall swing movement, thus, achieving the desired height and path down the fairway.
• Keep the angle of the leading hand – left hand for right-handed golfers - as consistent as possible to ensure solid contact with the ball.
• Think of a windmill when making the swing – smooth in its journey through the arc – so as to avoid choppy movements.
Link Resources
Golf Swing Experts Website:  http://golfswingexperts.com
Golf swing Tips website:  http://www.golfswingtipsmadeeasy.com/
Squidoo Beginners Golf guide: http://www.squidoo.com/beginners-guide-to-starting-golf
Face Book Site https://www.facebook.com/#!/golfswingexperts        Youtube video on Golf swing Tips and Golf swing Basics https://www.youtube.com/watch?v=egy2uG6F-Q0
