Batteries + Jumpercables = DC Welder
Intro: Batteries + Jumpercables = DC Welder
Here's the simplest welder you can make.
It's just a pair of jumper cables and a welding rod.
Oh yeah. And some batteries to power it.
I happened to have some nice juicy batteries in the form of a Golf Cart.
Here's me welding a trailer hitch with 1/8" 6011 rods. Welding current peaks at around 140-150 amps with these rods and around 120 amps with 3/32 6013 rods according to a Fluke 1010 clamp probe.
Greatly inspired by South Africans battery-welding their landrovers.
More battery welders
Also check out this great homemade AC stick welder.
Oops! Almost forgot a warning. DON"T ELECTOCUTE, BURN, OR BLIND YOURSELF. DON'T BREATHE THE FUMES OR DETONATE YOUR BATTERIES.
That said, read the specs for your battery. Big ones are designed to produce enough current for welding. Don't let the nay-sayers keep you from trying it. Check your batteries and don't overheat them. Lead-acid batteries can go into a thermal-runaway self-discharge mode.
Action photos by Andrea, video by Pete Lynne.
STEP 1: Cables and Rod
Here's the stuff.
The jumper cables were $12 from Harbor Freight.
The strip of bicycle innertube is optional, to wrap the end of an alligator clip and make it grip harder.
If you're feeling fancy you can replace one of your alligator clips with an electrode holder.
This nice one was made in India and cost $7 from Harbor Freight.
The welding rods I tried are 3/32" 6013 and 1/8" 6011, 5lbs for $6 or so. Available in Africa, S.America, anywhere.
You'll also want to wear gloves,
and a welding helmet, $16 from Northern Tool
STEP 2: Alligator Clip Orthodontics
Bend the alligator clip's incisors forward so the canines can grip the rod properly as seen in the 2nd photo.
Strengthen the alligator's jaw muscles with a wrapping of bicycle innertube strip.
STEP 3: Batteries!
My golf cart has 6 of these 6 volt T-105 size batteries that I bought used from THE GUY WHO MADE THEM!!!
They're in series making 36 volts total. I can clip in anywhere in the chain to get 36,30,24, etc. volts.
The batteries have about 220 Amp-hours capacity, so that means I could weld at 150 amps for more than an hour (consult books printed on paper for the details) without recharging. Plenty good since I'll never have a project with enough metal laid out ahead of time to spend that much time a-welding in a day.
If your batteries aren't as nice as this, don't worry, you can do plenty of welding with three old car batteries in series.
I got these from the guy who made them?
That's right, a family run battery manufacturer right in Sausalito in a little workshop.
It's really amazing, like an old time blacksmith's shop, but high-tech. They can make any size battery.
Alrick, the proprietor, grew up making batteries and he really knows his stuff.
He sells batteries to all the big boats there, and he knows exactly how long every brand of battery lasts in every set of conditions.
Don't bother him about your electric car though, he's been plagued about that sort of thing enough already.
Arc battery company
90 gate 5 rd. sausalito ca 94965
415-332-3272
Arc battery company
415-332-3272
STEP 4: Welding Tests
I welded on 1/4" thick cold-rolled mild steel plate.
I used DC reverse-polarity at 36,30, and 24 volts.
I used 1/8" 6011 rod and 3/32" 6013 rod
STEP 5: The Welds
A short arc but very hot. It melted deep and fast into the 1/4" plate.
I couldn't have stuck the rod to the plate if I wanted to.
These are the welds after chipping and brushing the slag off.
I did the right hand weld first with 1/8" 6011 rod at 36 Volts.
I've had the rods for a while and they're a bit damp and splattered a lot.
It's a deep good weld as you can see in the next photo of the backside of the plate, where it's melted through.
The mess at the top of the middle weld is trying a 6011 at 24 volts. Not enough juice, a lot of splattering. The full length bead next to it is a 6011 at 30 volts.
The left hand weld, the best looking one, is a 3/32" thick 6013 rod at 30 volts.
This golf cart is a good welder and I will definitely use it to weld projects in the future.
STEP 6: Arc Stabilizer and Stinger
Thanks to readers who recommended putting an inductor in series, called an "arc stabilizer".
Zan and I made one from a transformer we scavenged from a dead microwave oven. We used this method to chop out the secondary and wind 20 turns of 10-guage wire, which is all that would fit.
We left the primary intact, it doesn't affect the function here. An inductor gives the current "momentum" to blast through bits of flux and rust that get in the way. The arc sputters a lot less, welding is easier, and the welds are better.
I got a great Indian-made stinger (electrode holder) for $6 from harborfreight and replaced one of the jumper cable clamps with that.
Then I welded some repairs on this very badly rusted boat trailer. Too pitted to grind clean very well. I used 1/8" 6011 rod at 36 volts and it was fabulous. I melted good deep welds into all that rusty metal. Very satisfying.
We've got a self-propelled welder!
STEP 7: Cutting Steel With a Stick Welder
The bumper hitch on my 1978 Toyota truck was rusted rotten.
Ray and I used the golfcart welder with 1/8" 6011 rods to weld some beefy reinforcements on it.
The big toroidal series inductor seen here came from [www.accrc.org/ ACCRC] Maker Day. I should put a few dozen more turns on it to really smooth out the arc. We did some strong agricultural-style welding that isn't going to break or appear in textbooks.
Here's Ray cutting holes for the trailer safety chain to hook on.
We dipped the rods in water and then blasted and pushed the steel out of the way. It works well and makes a surprisingly clean hole while using less rod than you'd think.
Thanks to a reader who suggested dipping the rods in water- I can't find your comment now, what other nifty tricks do you have up your sleeve?
I also tried an improvised air-arc torch using compressed air. It didn't work at all. The air blast blew the arc away, chilled and froze the molten metal instead of burning it. I guess that's why air-arc cutting torches use 500 amps or more
101 Comments
Hayden’sIdeasAndCreations 5 years ago
pauldash29 6 years ago
GregoryS57 7 years ago
On the inductor (Arc stabilizer), could you wrap your coils around a round plastic rod storage box filled with welding rods as the iron core? Since you've got to have rods with you anyway this seems like it would accomplish both. Also, it seems like the 10 gauge wire you're using in the inductor is a "resistor" in the system... aren't the full amps of the circuit flowing through the inductor wraps? Does this smaller inductor wire get hot?
R-A 8 years ago
I'm quite curious, how do you control the Amperage when welding with batteries?
BuddyJ1 9 years ago
hello, i am buddy jeans from arizona. i am very excited to have this build as my next project. i love learning the right way in stuff. then i practice until i feel confident in exploring the limits. thank you for the tips and i will be safe.
BuddyJ1 9 years ago
andy.knote 9 years ago
I've wanted to do this since I saw them welding this way on "The Colony" Thanks for posting the Instructable.
Great Instructable. Good photos, nice job of covering the little details, great step-by-step instructions. Nice Work!
Zuma07 11 years ago
kendall giles 9 years ago
look at my comment above I use marine batteries
I used two marine batteries, with 9ga wire coiled to be the resistor between the two batteries, more wire= more resistance. I needed at lot more resistance than in the last pick but needed it small also so I coiled the the wire around the jack Handel so the coils will be the same size. I can't tell you how much resistance it is but I have several different coils of different sizes to very the amount of power depending on the welding rod you use, also the coils produce enough heat to melt a screw driver, when incerted inside the coil after being used for over a few hours
HammE 10 years ago
HammE 10 years ago
Also, would that be able to weld mild steel tubing for applications like welding a go kart frame?
smpash 12 years ago
wtuck 12 years ago
fishnfreak18 13 years ago
hintss 13 years ago
sconner1 12 years ago
Golf carts use deep cycle batts already.
Just try not to overheat them nor recharge while still hot and everything should be fine.
All batteries eventually wear out.
Sometimes you can revive "dead" lead acids with a little epsom salt.
This make it possible you could "recycle" (more like reuse) discarded batteries you can get for free.
hintss 12 years ago
or a welder...
okie1685 12 years ago
a farmer with about 10 old batters in the bed of a pickup had me back on the road before the engine in my truck got cold.. no charge thanks again mister rouse.
xBrainstormerx 14 years ago
