Introduction: Gooing Caps
Compared with the ordinary skateboard for
playing, the shock absorption device of this skateboard has changed greatly from tilt to vertical, so as to better buffer the bumps brought by the ups and downs of the skateboard. In addition, a handrail is added, which also has another function. Finally, a jet device is added at the front and back, which can better speed up and slow down
Step 1:
1. Build skateboard body
The main structure is made of high-strength and elastic aluminum alloy. At the same time, it takes into account the characteristics of light weight and firmness. The groove in the figure is for the purpose of being able to be fixed on the sliding plate well when the handrail is not used.
Step 2:
2 skateboard Foundation
In order to play a better role in fixing and buffering,
vertical structure is selected for assembly. In this structure, there is a buffer zone, which can make the bracket have more active space in the base, better match with the spring in the buffer device, and achieve better effect.
Step 3:
3 bracket and wheel for skateboard construction
The structure of bracket and wheel, borrow the common
baffle structure, to play a reinforcing role. Spring setting is vertical for maximum cushioning
Step 4:
4 structure of slide rail
The first is to help the novice quickly adapt to the
skateboard and find the feeling. And that's to increase comfort. When tired, you can feel like a child.
Step 5:
5. Perfect buffer device
Step 6:
6 complete the assembly
Step 7:
Compared with the ordinary skateboard for playing, the
shock absorption device of this skateboard has changed greatly from tilt to vertical, so as to better buffer the bumps brought by the ups and downs of the skateboard. In addition, a handrail is added, which also has another function. Finally, a jet device is added at the front and back, which can better speed up and slow down.
![Skateboard Contest](https://content.instructables.com/F4Z/49OU/JZSZW2FP/F4Z49OUJZSZW2FP.jpg?auto=webp&frame=1&width=320)
Skateboard Contest
