Introduction: Got Low Sound From Your TV Speaker
Then here the fix
Step 1: Want You Need and Tool
RCA cable
Ground loop isolator
Amp
You may need barrel jack for the amp
You may also need a dc to dc step up
wire crimp joints
RCA connector
Tool
Wire stripers
Volt meter
Step 2: Were to Get the Audio Signal and Power
Look for the plug that speaker for your tv
Look for the power supply it should have a label that say 12v 5v …. then use your volt meter to see if it is actually 12 or 5v if not you will need a dc to dc step up for what your amp power is
Step 3: Pluging in Your Amp and Tv Speaker
Cut the speaker from the plug then add the RCA connector to the plug
Then plug that into the Ground loop isolator then take the output and plug it into the amp
Then plug the amp in to power and take the speaker output and plug it into the tv speaker
