Gravity Fed Pellet Burner
Intro: Gravity Fed Pellet Burner
Hi,
This is my gravity fed pellet burner.
The air intake and the feeding rate can be adjusted depending on the intensity of heat needed.
Set to the minimum feeding rate, i get over 8 hrs of heat with a 40 pound bag of wood pellets.
Together the rocket stove and the burner work better then i expected,
Wood pellet are cheap and easy to find.
Since wood pellets are made from recycled wood, i guess this is somme kind of green way to heat my garage..
STEP 1: The Perforated Plate Is the Key to Success
- Pellets will fall on the perforated plate, slide down and form a pile. Fire wil waken the pile and make it crash. This will allow other pellets to fall into the burner. This process will continue as long as there are pellets in the container.
- The angle of the perforated plate is about 45 degres. The holes act in two ways, they allow air to feed the fire and hold the pellets as they fall. After a few minutes of burning the plate is red hot and every pellet that comes in contact with it quickly ignite.
- The space between the plate and the interior side of the square tube il about 1/4 inche so air can get in at all time.
You can see it work there:
http://www.youtube.com/watch?v=rEosHNLZJek&feature=g-upl&context=G2e8c2daAUAAAAAAAAAA
This burner could be install on different kind of heat exchanger device, it could just be an extension of the square tube ending to a chimney.
Any questions???
Any questions???
STEP 2: New Burner...
This is the new burner i made. Bigger holes and less steal. This model provides a better airflow...
STEP 3: Video
Made this video on how to ignite the pellet burner...
Cheers!!
https://www.youtube.com/watch?v=jpNxeTdrGXE&feature=g-crec-u
Cheers!!
46 Comments
mazz52son 6 months ago
beppemazzola 7 months ago
Beautiful project. I'm a beginner in this field. I have red most of the comments here and yet it's not clear to me if I can install and use this burner inside my apartment as part of my heater. Is it safe to have it working in the place where I live, making the assumption I have built it and the heater properly?
Seniortrader 7 months ago
briggstom1952 2 years ago
Seniortrader 2 years ago
Goodlumen 3 years ago
KevinW277 4 years ago
Seniortrader 4 years ago
Finnish-guy 9 years ago
Hi Seniortrader,
After some consideration I decided to upload this video, which
presents my older burner in action. This design surely violates both Carry and
Wiseway patens, so making a commercial product from this design can be
problematic.
This time I integrated the burner with my house heating
stove. It seems to work pretty well also this way.This is potentially fire-hazardous so I really
do not recommend anyone to do this at home. Certainly this needs continuous monitoring
during the operation, and should not left without it in any circumstances.
And typos.... Clarry and Wiseway patents.... and most
probably something else…. How could I
edit my sent replies???
g6956564 8 years ago
Hi
Have a look at my hobby project. Its a controller unit for biomass.
https://github.com/sedevc/openBC
Plasanator 9 years ago
great job
Seniortrader 10 years ago
cube122 10 years ago
I'm using 8mm pellets and 8mm holes 100x100 tube
When i looked your design it's not so tight so air can get sides
I think your system works because "stop" is very loose and air can get sides and over" im not sure but i find out today when i make modifications...
