Introduction: Greeny the Smart Greenhouse
Hello Everyone
Now im here to share my final project at my school, It called Greeny The smart greenhouse. The first things i want to apologize for my english and the second i want to tell you about Greeny, Greeny is a smart system who can growth your plant inside greenhouse. Greeny have a temperature control system and also watering system. Greeny also can give you report about environtment condition inside greenhouse from web server , Datalogger and LCD.
And now Lets make it ..........
Step 1: What Will We Need ?
Ok now i want to tell you what component need
1. Intel Galileo Gen 2
2. Arduino Uno
3. TEC ( Thermoelectric) cooling device .
4. Water Pump
5 .15 Watt Led for heater device
6. 1 watt Led 2pcs
7. Micro SD 16GB
8. DHT22 Sensor
9. Soil Moisture Sensor
10. LDR
11. Relay 4 Channel
12. LCD 20x4
13. LCD i2c module
14. RTC module
15. Fan
16. Resistor 10k
17. IC 74HC125
18. Water Pump
19. Breadboard
20. Wires
21. IP CAmera
22. Home Router
23. LAN Cable
24. Wood +Acrylic Box (Platform Greenhouse)
25. Internet Connection
For all of that i spend around 4 Million Indonesian Rupiah ($308,00)
Step 2: Electrical Circuit
Now i will tell you about Greeny Electrical Circuit Connection
Intel Galileo
Pin 2 ------------------ Data IN DHT22
Pin 3 ------------------ Data Out DHT22
Pin 5 ------------------ Relay CH1 (TEC)
Pin 6 ------------------ Relay CH2 (water pump)
Pin 7 ------------------ LED 1 watt
Pin 8 ------------------ Relay CH3 (LED 15 watt)
Pin A0 ---------------- Soil Moisture sensor
Pin A1 ---------------- LDR
Pin A4/SDA --------- SDA RTC Moudule
Pin A5/SCL --------- SCL RTC Module
Arduino Uno
Pin 2 ---------------- Data Pin DHT 22
Pin A0 -------------- Soil Moisture Sensor
Pin A4/SDA --------- SDA i2c Moudule
Pin A5/SCL --------- SCL i2c Module
About Using Intel Galileo and Arduino Uno
why i use Intel galileo and also Arduino Uno ? because i have some problem with using 2 i2c device at intel galileo, i try to find some literature to fix that problem, i try each solution but i still cant fix that problem. and i try to use my old arduino Uno just for displaying environtment inside greenhouse to LCD. thats why i use Intel Galileo and Arduino Uno
DHT22 Work around for Intel Galileo
First i use DHT22 and DHT11 for my Arduino Uno i didnt get any problem to use that . but when i use Intel Galileo i get a problem, when i attach it directly to Intel Galileo, DHT22 didnt give a value of Temperature and Humidity. After that i try to find any Solution for my problem. and i found the solution at Intel Comunity . From there i know that Intel Galileo cant work with one wire device .
He said
"The main reason the DHT temperature and humidity sensor does not work
with the Galileo is because of the tight requirements of one-wire device like the DHT11 and DHT22 sensors. With just one wire, DHT and many other one-wire devices will not work with the Galileo because the Galileo takes too much time when switching a pin from one direction to another. This is because the Galileo uses IO expanders for the gpio that controls the pin direction and those IO expanders are connected to the Galileo via I2C. "
the only one way to make DHT22 work around Intel Galileo is put IC74HC125 as tri-state buffer and Resistor 10k
for detail you can visit DHT22 Workaround Intel Galileo
Data Logger Intel Galileo
you can access datalogger file from SD card who attach in Intel galileo. if you want to see datayou need to take off micro sd from intel galileo and open it at computer with notepad
Tips for Using TEC
I use TEC because my friend tell me that TEC is a fantastic Cooler he can make ice without water . just like in picture it can reach -17.6 celcius WOW!! but in real i can left it sleep when the temperature down from 29 to 26 celcius. the question , why so take the time to down just 3 celcius ? the answer is i make a mistake in mechanical and placement the TEC. i just use Aluminium foil and Fan to bring the cool air from TEC to Greenhouse. If you want your TEC work maximum you should use cooperplate like processor cooler. it can make better result .
My friend from sabisa Farm Bogor Agricultural University tell me that for some reason better we replace the TEC with sprayer like Fire Alarm in building . Thanks for advice Mr Dirga and My friend from sabisa farm
Step 3: Make Web Server for Monitoring and Connecting to Intel Galileo
Now i will tell you how to make web server for monitoring environtment inside greenhouse. i make the web with HTML , CSS and Bootstrap .
for the tool, i use
TP-link MR220 Router
IP Camera Tp Link NC200
Notepad++(software)
after that connect IP camera to router with LAN Cable.
Configuring Network
This step i will tell to make a wireless connection network. it can make you able to access web server monitoring from your computer or gadget. To make the network i follow guide from manual book. after i make the network i make an address reservation for intel galileo and ip camera.
for Intel Galileo i give IP 192.168.0.105
for IP Camera i give IP 192.168.0.106
Connecting Intel Galileo to Router
To make Intel Galileo connect to Router just plug LAN cable from ethernet port in Intel Galileo and and connect it to LAN port at router . And This important when you configure wireless network to enter MAC address Intel Galileo. you can find it at sticker near Ethernet port .
Note : the code i will show next in Code step
Step 4: Code
And now we arrived at my favorite step. we will make the code or i like to call it "Ngoding Time"
here i will give you the code of greeny the smart greenhouse including web server monitoring code
you can download code below
Instruction :
Upload Greeny_Log1 File to Intel Galileo
Upload Greeny_Arduino to Arduino Uno
Step 5: Growth It !!
If you want to access Monitoring web server, you need to be in area of wireless connection (i still trying to make it can be accessed outside network ) connect to wireless connection and open your browser and access 192.168.0.105. And ....... Greeny will give you information about your greenhouse
After too long process finally i finish to Make greeny the smart greenhouse . i hope you enjoyed reding and try to make this . thanks fro reading and Sorry for my english
and last from me
" Think Smart and Growth it "
(Khoirul Iman)
Circuits Contest 2016
7 Comments
Question 3 years ago on Step 5
I want to ask about the Controller Intel Galileo because I use the Gen 1 Version. What should I change to make it suitable with that version?
Question 3 years ago on Step 2
hi i am trying to make this for my school project , and i am stuck in the electrical wiring process. Can you email me the high resolution pictures of the electrical circuit ?
5 years ago
thanks for sharing it good information
5 years ago
Thank you. I can see this a large scale application use. You got my vote.
Reply 5 years ago
thanks you sir :)
5 years ago
This is a great setup :)
Reply 5 years ago
thanks sir :)
