Introduction: Art Made Simple: Create a Grid Screen for Perfect Proportions
What This Project Is About?
Have you ever tried to copy or enlarge a picture using the grid method?
Normally, you draw small squares on your paper and your reference photo. Then, you copy one square at a time to keep the proportions right.
But there’s a problem — after finishing your drawing, you have to erase all those grid lines, and that can spoil your artwork.
This project solves that!
We’ll make a reusable grid screen that you can place on top of your drawing paper. It helps you draw with perfect proportions — without marking your paper.
You can make it in two ways:
- Using cardboard and string, or
- By 3D printing a plastic grid frame.
Step 1: Materials
- A piece of 1.1 mm cardboard
- Glue
- Small nails or pins
- String or thread
- A wooden board (as a base for building the grid)
- A sheet of graph paper
- 3D printed grid frame (if you have access to a 3D printer)
Step 2: Make Using Cardboard
Step 1: Set Up the Base Grid
- Stick your graph paper firmly onto the wooden board.
- Mark all the points where the grid lines cross.
- Hammer small nails or push pins at these points — these will hold the string.
- Take a long piece of string and tie it between the nails horizontally.
- Then add vertical strings the same way, forming a net-like pattern.
- Apply glue gently on the strings to make them firm and hold their shape.
- When the glue dries, remove the strings carefully from the nails — now you have a flat grid made of string.
- Cut out a window or square shape in your cardboard (this will act as a frame).
- Stick the glued string grid to this frame.
- Trim off any extra string on the edges.
- You can make two identical grids if you want — one for your reference image and one for your drawing pape
Step 3: 3D Printed Grid
If you have a 3D printer, you can print the grid instead of using string.
- Use the STL or GCODE files provided (or design your own simple grid).
- Suggested print settings:
- Layer height: 0.2 mm
- Wall thickness: 1 mm
- Print speed: about 70 mm/s
- Print two grids — one for your reference picture and one for your drawing paper
Step 4: How to Use the Grid Screen
- Place one grid over your reference image.
- Place the other grid over your drawing paper.
- Make sure both grids are aligned (so each square matches perfectly).
- Now, copy the contents of each square one by one.
You’ll notice how easy it becomes to get the correct shapes and proportions — and when you finish, just remove the grid! No erasing required.
Step 5: Results and Benefits
lean artwork: No grid lines to erase.
Reusable: You can use the same grid again and again.
Good for students: Helps beginners learn accurate drawing.
Fun and creative: Combines art, craft, and 3D printing.
Step 6: Tips for Better Results
- Keep your grid frame flat and clean.
- Use transparent plastic or acrylic if you want to see the paper clearly.
- Align the grid edges with your paper corners to keep proportions correct.
- Label the grid squares (A1, A2, etc.) if needed for more accuracy.
Step 7: Conclusion
The Grid Drawing Screen is a smart and simple art tool that makes drawing much easier.
It’s a great project for art students, makers, and teachers — combining traditional drawing skills with hands-on creativity using 3D printing or simple materials.
