Introduction: Grill Starter - Smal But Very Usable Device
About: I love to make DIY projects with my son
Grill Starter is the project which don't require many supplies and time to construct. The device is simple but very useful and brilliant. It allows to start barbecue grill in just a minutes with great red, hot charcoal ready for cooking.
- pipe
- piece of metal for a handle
Step 1: Making the Chimney
First step is to make chimney. I used pipe leftover from mounting my fireplace at home.
The pipe is 2mm thick and has 12cm in diameter. I cut it to have 35cm of height.
Step 2: Making the Grate in Chimney
Now it's time for something which will hold the coal inside and still deliver the air from bottom to top. I divide the pipe to equal parts around the circle at the bottom and then draw the straight lines up to 10 cm. Then I cut the stripes along this lines in the pipe.
I cut every 4th stripe at half and then bend all of them to the inside using the hammer.
Step 3: The Handle
The chimney need to have the handle. The longer is better, because it won't heat so much during usage. I made a handle from some scrap of metal bent using hammer. Then I weld it to the chimney.
TIP: it's good to add some isolation to the handle. Without isolation You need kitchen gloves to use the device.
Step 4: The End - Using Grill Starter
That's all - starter is ready.
Now You need to place it on something stable. Then add to the inside some wood scraps or chemical grill starter. Put a scrap of paper underneath. Then add a coal into the chimney and fire the paper.
Paper will light the wood scraps, then the fire will grow due to the natural air flow (from bottom to top). After few minutes You will notice that You can see heat inside the chimney. Wait a few minutes more and You will have good, hot coal for Your grill. Grab a handle with kitchen gloves (heat resistant) and pour the hot coal into the grill.
Now enjoy Your barbecue ! :)
