Introduction: Grilled Watermelon and Cheese
It is BBQ season and there is always someone asking for a vegetarian dish. With this instructable you are now prepared and have an impressive meal in your repertoire.
Step 1:
What you need:
barbecue cheese
watermelon
salvia
sticks
Marinade:
olive oil
garlic
thyme
jalapenos
For serving:
olives
limes
And wooden skewers.
Step 2: Marinade
Chop the thyme and mince the garlic into a mortar. Season with salt and pepper and add olive oil. It is optional if you want to add jalapeno or limes, you can adapt to the taste of your guests.
Then use the pestle and crush everything, set the marinade aside and let the oil get infused by the garlic and herbs.
Step 3: Watermelon
Use a big chef's knife to split the water melon, then cut wedges with side lengths of 4cm (2inches) and thick as a thumb. If it is too thin it will burn before the cheese is done.
Step 4: Barbecue Cheese
Cut the barbecue cheese into quarters. To have a better texture you can use a burger press.
Step 5: Strung
Alternate the watermelon wedges and cheese wedges on the wooden skewers. Separate them with salvia leaves, finish both ends with olives or limes. Rub the marinade on the barbecue cheese wedges. Use only one side and grill the sticks first on that side.
Step 6: Grilling
Each side needs 4 to 5 minutes on the grill. Start with the marinade side or it will turn black. If your grill has already been used for other meat, use an aluminium foil bowl.
Step 7: Turning
After 4 to 5 minutes you turn the sticks around with a swift flip because the cheese will soften inside. Then serve the sticks with some lime juice sprinkled on them. Grilled watermelon is sweet and smokey.
Runner Up in the
Makerspace Contest 2017
Gluten Free Challenge 2017
First Time Author Contest
3 Comments
5 years ago
What sort of cheese do you recommend for this recipe?
5 years ago
This sounds excellent.
I've used a simpler recipe with great results as well. Once I've cut the watermelon into quarters I put them in a gallon size freezer bag with 1.5 cups of soy sauce and let it sit for about 30 minutes before placing it on the grill.
5 years ago
Interesting. I have never had grilled watermelon before. I am going to have to try this.
