Introduction: Grolsch Keychain in Under 5 Minutes
In this instructable I will show you how to make a key trinket from a Grolsch bottle cap.
Step 1: Gather the Materials
You will need:
- bottle cap
- key ring with chain
- copper wire or other material
- 1mm and 3mm drills
- pliers for cutting the wire.
Step 2: Drilling the Bottle Cap
For this step you have to remove the red gasket from the cap.
Drill a hole in the bottom like in image. Make sure the chain can fit in the hole.
Now drill 2 side holes for the wire. It is better if the wire enters hard through the hole.
Step 3: Cutting the Wire
Measure the length of wire needed and cut it.
Step 4: Attaching the Chain
With the last link of the chain in the hole push the wire all the way through the cap so it locks the chain in place.
Step 5: Finishing Touch
Put the gasket back on and you're done. Your cute keychain is finished.
