Introduction: Grove 3 Axis Digital Compass
This is the fourth tutorial of a series of tutorials where I show you how to connect Grove sensors and Components to an Arduino and to get started for a robot project using these sensors. In the last few instructables, I showed how to get started with I2C Motor Driver, Single Axis Analog Gyro and a Thumb Joystick, also check that out if you are here for the robot build.
In this tutorial I'm going to show you how to get started with a Grove three Axis Digital Compass with an Arduino.
So lets get started.....
Step 1: Tools and Components
All that you need for this tutorial is-
- Arduino UNO
- Grove 3 Axis Digital Compass
- Jumper wires
Note- No soldering skills are required to build this project, but it is good to know how to solder there are a good soldering tutorials on YouTube that can help you get started.
Step 2: Getting Started
I2C is a is 2 pin communication system the 2 lines are the SDA (data line) and SCL (clock line), this reduces the number of pins of the Arduino dedicated to drive the Digital Compass. There is a good documentation of Arduino I2C in the Arduino website, you can read to that to get started with I2C.
Step 3: Hardware
Now time for the connections the Arduino has the SCL line on analog pin 5 and SDA line on analog pin 4.
Here is how you need to connect he hardware -
- Arduino analog pin 5 - Grove I2C Motor Driver SCL
- Arduino analog pin 4 - Grove I2C Motor Driver SDA
- Arduino +5V - Grove I2C Motor Driver VCC
- Arduino Gnd - Grove I2C Motor Driver Gnd
After you connect the hardware it is time to upload the code......
Step 4: Code
The code is quite simple and all it does is reads the compass readings and prints it out on a serial monitor. The Compass calibrates for a few seconds when you run the code make sure not to rotate or disturb the compass while this happens and after it completes you should get a fine stream of data from the sensor.
<p>// Reference the I2C Library<br>#include <wire.h>
// Reference the HMC5883L Compass Library
#include <hmc5883l.h></hmc5883l.h></wire.h></p><p>// Store our compass as a variable.
HMC5883L compass;
// Record any errors that may occur in the compass.
int error = 0;</p><p>// Out setup routine, here we will configure the microcontroller and compass.
void setup()
// Initialize the serial port.
Serial.begin(9600);</p><p> Serial.println("Starting the I2C interface.");
Wire.begin(); // Start the I2C interface.</p><p> Serial.println("Constructing new HMC5883L");
Serial.println("Setting scale to +/- 1.3 Ga");
error = compass.setScale(1.3); // Set the scale of the compass.
if(error != 0) // If there is an error, print it out.
Serial.println(compass.getErrorText(error));
Serial.println("Setting measurement mode to continous.");
error = compass.setMeasurementMode(MEASUREMENT_CONTINUOUS); // Set the measurement mode to Continuous
}</p><p>// Our main program loop.
void loop()
// Retrive the raw values from the compass (not scaled).
MagnetometerRaw raw = compass.readRawAxis();
// Retrived the scaled values from the compass (scaled to the configured scale).
MagnetometerScaled scaled = compass.readScaledAxis();
// Values are accessed like so:
int MilliGauss_OnThe_XAxis = scaled.XAxis;// (or YAxis, or ZAxis)</p><p> // Calculate heading when the magnetometer is level, then correct for signs of axis.
float heading = atan2(scaled.YAxis, scaled.XAxis);
// Once you have your heading, you must then add your 'Declination Angle', which is the 'Error' of the magnetic field in your location.
// Find yours here: http://www.magnetic-declination.com/
// Mine is: -2��37' which is -2.617 Degrees, or (which we need) -0.0456752665 radians, I will use -0.0457
// If you cannot find your Declination, comment out these two lines, your compass will be slightly off.
float declinationAngle = -0.0457;
heading += declinationAngle;
// Correct for when signs are reversed.
if(heading < 0)
heading += 2*PI;
// Check for wrap due to addition of declination.
if(heading > 2*PI)
heading -= 2*PI;
// Convert radians to degrees for readability.
float headingDegrees = heading * 180/M_PI; </p><p> // Output the data via the serial port.
Output(raw, scaled, heading, headingDegrees);</p><p> // Normally we would delay the application by 66ms to allow the loop
// to run at 15Hz (default bandwidth for the HMC5883L).
// However since we have a long serial out (104ms at 9600) we will let
// it run at its natural speed.
delay(66);//of course it can be delayed longer.
}</p><p>// Output the data down the serial port.
void Output(MagnetometerRaw raw, MagnetometerScaled scaled, float heading, float headingDegrees)
Serial.print("Raw:\t");
Serial.print(raw.XAxis);
Serial.print(" ");
Serial.print(raw.YAxis);
Serial.print(" ");
Serial.print(raw.ZAxis);
Serial.print(" \tScaled:\t");
Serial.print(scaled.XAxis);
Serial.print(" ");
Serial.print(scaled.YAxis);
Serial.print(" ");
Serial.print(scaled.ZAxis);</p><p> Serial.print(" \tHeading:\t");
Serial.print(heading);
Serial.print(" Radians \t");
Serial.print(headingDegrees);
Serial.println(" Degrees \t");
}</p>
