Introduction: Grove Thumb Joystick
This is part three of a series of instructables where I take standard Grove senors and components and wire it up with a Arduino. In the last two tutorials I showed how to connect an I2C motor driver and a single axis analog Gyro to the Arduino, be sure to check that out. These tutorials are a part of a robot project using all of these sensors.
In this instructable I'm going to show you how to connect a Grove Thumb Joystick to the Arduino.
So lets get started.....
Step 1: Tools and Components
All that you need for this instructable is -
- Arduino UNO
- Grove Thumb Joystick
- Jumper Wires
Note- No soldering skills are required to build this project, but it is good to know how to solder there are a good soldering tutorials on YouTube that can help you get started.
Step 2: Hardware
Time to connect the Arduino to the Grove Thumb Stick, the connections goes as follows -
- Arduino +5V - Grove Thumb Joystick VCC
- Arduino Gnd - Grove analog Joystick Gnd
- Arduino A0 - Grove analog Joystick X axis
- Arduino A1 - Grove analog Joystick Y axis
After getting the hardware connected, it is time to upload the code...
Step 3: Code
All that the code does is reads the analog value and does some mathematics and prints it out on a serial monitor. The processed data can be used to control a robot which I will show soon.
<br><p>void setup() {<br> Serial.begin(9600);
void loop() {
int sensorValue1 = analogRead(A0);
int sensorValue2 = analogRead(A1);
Serial.print("The X and Y coordinate is:");
Serial.print(sensorValue1, DEC);
Serial.print(",");
Serial.println(sensorValue2, DEC);
Serial.println(" ");
delay(200);
}</p>
