Introduction: Low-tech Oyster Mushrooms Culture
This tutorial describes the domestic cultivation of edible mushrooms.
It was entirely realised by the association Low-tech Lab. More tutorials for low-technologies are available on our website, do not hesitate to visit us ! The original tutorial can be found here.
Advantages of growing gray oyster mushrooms:
Ecology/Money savings
Fungi are one of the few organisms that feed on lignin and cellulose.These elements are present in many wastes from agriculture and other activities (straw, coffee grounds, sawdust, etc.). It is therefore an excellent way to recover these wastes. At the end of mushroom cultivation, it is possible to reintegrate the mycelium and substrate used for cultivation into the compost. Mushroom growing can therefore provide additional income for producers of this type of waste.
- Nutrition
Oyster mushrooms are not among the most nutritious foods, however they are a source of several interesting elements: vitamins B3 (niacin), B2, B5, minerals (copper, phosphorus, potassium, iron, zinc), and oyster mushrooms contain more protein than most vegetables.
Stages of cultivation:
- The mother spawn: The starter spawn (or mother spawn) is made from a fresh and healthy mushroom or can be bought from a "spawn" producer. The "spawn" is the mycelium of the mushroom grown in a sterile medium that is used for propagation. The mother crop is like "a seed" which allows to start several mushroom cultures.
- The invasion of the spawn: With the spawn of the mother culture we can then inoculate recipients that contain the substrate, the mycelium will invade the entire substrate. Once the substrate is completely colonized by the spawn, the last phase begins.
- Fruiting and harvesting: When the substrate is completely invaded, it is necessary to cause a change in the environmental conditions (T°C, light, CO2 concentration) and allow fruiting, which is the appearance of the part of the fungus that is consumed (foot and cap). All you have to do is harvest your mushrooms and eat them.
Materials
- Petri dish
- Alcohol
- Cardboard
- Plastic bottles
- Fresh mushrooms
- Cotton
- Substrate (wood chips, coffee grounds, sawdust, straw,...)
Tools
- Scalpel, knife
- Sterilization, pasteurization tools
- Sterilize your petri dishes, knife, cardboard
Step 1: Sterilization and Preparation of Mother Spawn
Note : Cardboard has the advantage of being a "selective" culture medium because it is low in nutrients and sugar. Most contaminants need sugar in the substrate to grow, whereas mycelium (of species growing on wood) can be satisfied with cardboard.
- Sterilize the Petri dishes (with 70% ethanol and/or under UV) or glass jars (boil them for 15-20min.)
- Cut out pieces of cardboard 3 cm side.
- Sterilize the pieces of cardboard by soaking them in boiling water for example. If you have one available, you can use a microwave to sterilize your jars and cartons. Moisten the cartons well, without soaking them before placing them in the microwave.
- Then place your pieces of cardboard in glass jars or Petri dishes. The cardboard must be well moistened but not completely soaked with water (let it drain for a few moments).
- Meticulously wash the mushroom.
- Dip the scalpel/knife in alcohol and then heat it in red with a flame (no smoke).
- Let it cool for 10 seconds.
- Cut the oyster mushrooms lengthwise and take a small piece from the neck of the oyster mushrooms (see photo).
- Place the oyster mushroom pieces on the cardboard in your Petri dishes. Inoculate at least 5 Petri dishes for a better chance of success.
- Place the Petri dishes in an incubator where there is no light with a temperature between 25-30°C. You must then wait for the mycelium to invade the entire box 7-15 days before inoculating your bottles with substrate.
Step 2: Preparation and Sterilization of Substrate Bottles
The mushrooms we intend to grow for consumption must be able to colonize the substrate before other fungi and bacteria. To this end, we sterilize the substrate and the bottle to which we will add the previously cultivated mycelium (free of any contaminants). This technique gives the cultivated mushroom a head start over the others.
- Put the wood chips in a container.
- Add water until the chips are completely covered.
- Add about 3% of the weight of the shavings in calcium carbonate (chalk or crushed shells of crustaceans).
- Cover the mixture and let it stand for one day to allow pathogen endospores to develop and be more easily removed afterwards.
- Fill the plastic bottles with your substrate. It must have a moisture content of 60-65%. Pierce the caps of the bottles and put a cotton plug at the neck, which allows gas exchange while preventing unwanted germs from entering. Close with the perforated caps.
Note: To know the right level of humidity, press a pellet of sawdust, a few droplets should flow and not a trickle of water.
Sterilize the bottles containing the substrate. Here we left them in a solar oven for one day. It is also possible to use a microwave. Let them cool down.
Step 3: Substrate Inoculation
- Open the sterilized bottles to inoculate them with your mother spawn, rich in mycelium, delicate passage because it is necessary to be fast enough to limit the risks of contamination during the opening of the bottles. It is important to work in a sterile environment during this operation (clean hands, clean clothes, etc...).
- Using tweezers previously sterilized in rubbing alcohol, place the ends of cardboard boxes covered with mycelium on the substrate of your bottles.
- Close the bottles immediately and put them in your incubator at a temperature of 20-30°C, without light.
- Using tweezers previously sterilized in alcohol at 70°C, place the ends of cardboard boxes covered with mycelium on the substrate of your bottles.
Step 4: Fruiting and Harvesting of Mushrooms
In the forest, the mycelium lodges under the bark in the semi-darkness; in autumn, when it starts raining and the temperature drops, this causes stress that pushes it to bear fruit in order to reproduce.
This fruitification initiation is by far the most delicate stage in the cultivation of mushrooms. The grower must implement an "initiation strategy" in order to produce a change in environmental variables to trigger the formation of primordias (mushroom embryo).
The four main environmental factors to be controlled during fruit initiation are: humidity, aeration, temperature and light.
- Humidity:
High humidity between 95% and 100% should be provided by light and regular watering. The substrate must be placed in conditions close to fog when it arrives in the fruiting chamber. When the primordias begin to form, a gradual decrease in moisture to 90% is generally beneficial.
- Ventilation:
Good aeration favours the appearance of primordias. Thanks to aeration, the carbon dioxide (CO2) content decreases rapidly while oxygen (O2) increases.
- Temperature:
Many species will not form fungi until the temperature decreases. The ideal time to vary the temperature (and other factors) is when the substrate is completely colonized. When the temperature is changed, it will take between 24 and 72 hours for the temperature inside the substrate to equal that of the ambient air.
- Light:
In nature, light acts as a warning to the mycelium that it should form fungi so that their spores are dispersed in an open environment. Light plays a role in the elongation of the foot and the development of the cap of the fungus. Ideal lighting conditions (intensity and wavelength) vary from species to species. Indirect sunlight, or light filtered by the forest canopy, is considered ideal for woodland mushrooms. The photoperiod and specific wavelengths have not yet been established for all species of fungi. Direct sunlight or high intensity light is harmful to the mycelium. Neon lights are not harmful to the mycelium and can be used for indoor cultivation.
Harvest
- Once the mycelium has colonized all the substrate and the bottle is white, store the bottles in a place with (indirect) light, well ventilated and if possible in 10 and 15°C.
- Pierce holes 1.5 cm in diameter when you feel or see balls of primordias through the bottle.
- Water the primordias well (3-4x/d in diffuse spray). As soon as we have primordias, they double in volume every day. Under good conditions you can get ready oyster mushrooms in 3-4 days.
- Harvest the oyster mushrooms before their hats turn up. Harvest the bunch by turning it over completely with your hand, all at once.
Potential harvest : 750g to 2kg of mushrooms for 1kg of substrate depending on the maturity of the mushrooms and the number of harvests. Under good conditions, 3 to 4 harvests can be obtained, spaced 7 to 14 days apart over a period of 45 and 55 days. More information is available in the the book by Paul Stamets : Growing gourmet and medicinal mushroom.
Step 5: References
This tutorial was experimented and created by the association Low-tech Lab. More tutorials are available on our website, don't hesitate to visit us !
More resources can also be found here :
- Paul Stamets' "Growing gourmet and medicinal mushroom"
- General tutorial on small-scale mushroom culture
- Ideal environmental conditions for oyster mushroom culture
- Temperature and humidity effects on mushrooms formation
