Introduction: Growing Gourds (Ridge Gourd, Bitter Gourd and Snake Gourd)
It is spring... Time for garden enthusiasts like me to wake up and prepare the backyard to plant our own vegetables... Even people with very little space use their terrace to plant vegetables in containers. Gourd varieties like Ridge gourd, Bitter gourd and Snake gourd are some of the popular vegetables which can be very easily grown in the home garden. These plants do not require much attention. However, by putting in a little more effort you will enjoy a great yield from the same plant from which you used to harvest very few fruits only.
A step-by-step instructable on growing Ridge Gourd at your home garden... These methods apply to other varieties of gourds like snake gourd and bitter gourd also.
Step 1: Seeds
Let us start with seeds...
Either you can save seeds from previous year's fruits allowing one or two to fully mature and dry in the plant itself or you can buy seeds from shops.
in the first picture you can see the ridge gourd seeds being collected from last year's dried fruit. The seeds are protected by the sponge-like network of fibers. You can extract the seeds from the fruit whenever you are planning to plant.
The second picture shows the seeds stored in cow dung. You can harvest the matured seeds and press them into flattened fresh cow dung and dry it in shade. Cow dung is natural protector and will not allow any pests to damage the seeds. You can break the dried cow dung cake and take out the seeds any time.
The third picture is of the store-bought seeds. These seeds are treated with chemical pesticides and are artificially colored to show the presence of pesticides. Take care while handling store-bought, chemically treated seeds and wash your hands thoroughly afterwards.
Step 2: Pit Preparation, Germinating and Planting
- Select an area where you can erect a trellis to support the plant, which also receives full sun light.
- Mark 2 feet x 2 feet area and clean all vegetation
- Dig a pit of about one foot in depth. Keep the soil separately
- Mix compost with this soil and refill the pit
Directly planting the seeds
Either you can plant the seeds directly in the prepared pit or germinate the seeds separately and transplant. You can see in the first picture that I have planted seeds holes directly in the prepared pit and watered. You can thin out to four or five when the seeds germinate and grow up
Second picture shows the dug-out soil being mixed with compost
Germinating and transplanting seedlings
You can also germinate the seeds separately and then transplant. You can use paper tea cups, polythene bags or any other container for this.
Another natural method is to wrap the seeds in banana stem with moist soil. The banana stem will help in retaining the moisture and will not allow the seeds to go dry. You can open up after about ten days and transplant the sprouted seeds in the prepared pit.
Step 3: Care for the Young Plant
I have transplanted two seedlings to the prepared pit. These photographs are of transplanted seedlings after 15 days. You need to provide good support to these young plants till they reach the height of the trellis.
I have provided support with coconut leaf stalk and tied the seedlings loosely with fiber from Banana stem
Step 4: Lateral Shoots and Tendrils
Lateral shoots grow from every node of the plant. Remove all laterals below the trellis level. These laterals will hinder the growth of main plant and make it unmanageable.
The tendrils, a specialized stem with a threadlike shape, are used by climbing plants for support by twining around nearby hosts. Pinch away all tendrils. We do not need them as we will provide support and guide the plant on the trellis system.
Step 5: Trellis
The plants need a trellis system to grow and spread. You can make one using timber poles and GI wires about seven to eight feet above the ground level
Step 6: Pruning and Training
- Allow the plant to grow without any laterals and tendrils about 12 nodes above the top of the trellis
- Now prune the main stem
- Lightly tie the stem with the trellis wire using a string. I have used the fiber from the banana stem for this
- You may find laterals growing from the nodes. Do not allow any laterals below the trellis
- Count each lateral to 12 nodes and prune the rest. Remove all tendrils also
- Train the vine over the trellis system by tying the laterals with a string.
There are different views as to pruning the laterals after how many nodes. Some people suggest to prune after 5 nodes. But in my experience, I have noticed that the nodes between fourth and tenth produce good quality fruits, so I prune the shoots after every 12th node.
Step 7: Watering
Water judiciously. Under-watering as well as over-watering will destroy the plant. You can visually inspect the plant everyday and water as required. There is no set rule.
Step 8: Fertilizer / Manure for the Plant
If you raise chicken, goat or any cattle, you can use their waste as manure for the plant. We collect goat dung from our baby goat and add it to the plant. We also make compost from kitchen waste using an old broken bucket as compost bin. The digested slurry from a bio-gas plant also makes a very good manure.
Step 9: Prevention Against Pests
Normally, gourds are rarely attacked by pests. However, prevention is better than cure...
We do not use any chemical pesticides at our home garden. We use a paste made with equal amounts of onion, ginger, garlic and chilies, dilute it with water and spray on the foliage. You can use a hand sprayer or just spray it on the plant with your hands. The solution is not harmful like chemicals. However, take care not to get this in your eyes as it may hurt...
Step 10: Male and Female Flowers
Shortly after training the vine on the trellis, you may find lots of flowers on the plant. All gourd varieties produce male and female flowers. A female flower can be distinguished by the small fruit attached to the flower. The male flower is just plain without any fruits. You can see the male and female flowers in the pictures here.
Step 11: Pollinating the Flowers
Gourds have separate male and female flowers. The female flower with a small fruit attached to it needs to be pollinated to grow into a matured fruit. Honey bees and some insects help in pollinating the flowers. However you can find lots of unpollinated young female flowers withering away. It is a good practice to always hand-pollinate gourds (this is possible only in kitchen garden in a small scale). Pluck a fresh male flower and rub it over a female flower to transfer pollen. You can use a soft brush also for pollination.
We got lots of honey bees in the garden which help in pollinating flowers. They are friendly and never attack unless disturbed. However, use of chemical pesticides will kill or drive away the bees from your garden
Step 12: Fruits of Your Labor
The pollinated female flowers slowly mature into fruits ready for harvest. You can see here that an unpollinated female flower has withered and died.
Step 13: Harvest in Time
Harvest the fruits at young stage before the skin becomes thick, otherwise the fruits will become inedible with lots of fiber. If you find any ripe gourd, just leave it in the plant itself. You can then collect the seeds when it completely dries out.
Step 14: Bottom Line
Hope this instructable is helpful for people new to growing gourds at your backyard.
Do not have space to grow your own vegetables...? Don't worry... you can turn your terrace or window sill into a mini garden and grow in pots, grow bags or in plastic buckets.
Here you can see a picture of Ridge gourds grown in a pot at our home and the hand rails of the staircase used as trellis...
If there's a will, there's a way. Enjoy growing your own vegetables...
Full Spectrum Laser Contest
Spring's Coming Contest
304 Discussions
4 months ago
Sir, I'm from Texas. I've planted ridge gourd in our backyard and the yield is really good. But 70% of the yield is bitter. Initially thought its because of hot weather here but looks like thats not the case with everybody. Checked with couple of friends and they have good yield and no bitterness. What could be the reason for the bitterness and what should I do to avoid these bitter ridge gourds.
Question 6 months ago
Hi Antoniraj. Your "instructable" is very well made. My ridge gourd is about 45 or so days old at least and has grown nicely onto the trellis. But it has absolutely no flowers. I have fertilized it once with organic manure and once with 10:10:10 NPK, but no luck at all. Not a single flower. Any ideas and suggestions?
Thank you.
Question 6 months ago on Introduction
Hello sir
On my ridge gourd I am getting all male flowers , what can be done for the plant to produce female flowers
Thank you
Deepika
Answer 6 months ago
Hi, Prune laterals after 10 to 12 nodes. Wait for few days and you will get female flowers. Also reduce use of fertilizer
Question 7 months ago on Step 3
Hello, how high does the trellis have to be?
The main reason I'm asking is because your mentioned removing new lateral growths below the trellis height.
Thanks for sharing this.
Answer 7 months ago
Trellis height may be 5 to 6 feet, comfortable enough for one to walk below
7 months ago
Thanks so much!
I am thinking of growing hard shelled gourds on my allotment and drying them out to make trinket boxes, beautiful maracas, vases etc....
This will help so much 😁👍🌱🌦️
Question 8 months ago
I get very less no. of female flowers on sponge gourd vine. Secondly at a time there are only female flowers or male flowers. With the result pollination becomes difficult. Please suggest how to increase the yield and how to get both male and female flowers at the same time.
Question 9 months ago on Step 14
I planted seeds for ridge guard and bitter guard around the same time , the bitter gourd has started producing vegetable now. But the ridge gourd is not flowering yet. What should be done for flowering of ridge gourd.
Question 1 year ago on Introduction
Hi. Can we cross pollinate between sponge gourd and ridge gourd. female flower of sponge gourd and male flower of ridge gourd ? Please reply.
Answer 10 months ago
Yes honey bee pollinate female flowers from male flowers. New fruits are actually new variety seed,if different gourds are planted nearby
1 year ago on Step 5
Black spot are formed on leavers... 😞😞... Please fast reply
Question 1 year ago on Step 14
Why some of my ridge gourds are turn bitter ?? Can you please suggest me to overcome this ?
Question 1 year ago on Step 13
Hi i am growing bittergourd, snake gourd and ridge gourd i my home garden... i want to save seeds for next year... do they cross pollinate??? Or can i just save seeds for next year????
Question 1 year ago on Step 11
I made 8 foot height trellises and guided climbers bottle, ridge and snake gourds on to them. Plants have grown well and flowering a lot. But all female flowers are withering away soon after blooming.
If pollination is the reason for flowering withering, then hand pollination is not possible because of height of trellises and there are too many flowers.
What shall I do so as remedy the flower withering?
Question 2 years ago on Introduction
Hi, I grow my home garden. I have my ridge gourd here. But haven't had fruits, flowers only wither away. It's been some time it's there, now I am thinking of making more of them to a more convenient place so as to hand pollinate them. I wish to know if stem cuttings propagate of ridge gourd vines. Because I can't have seeds. Do stem cuttings propagate?
Question 2 years ago on Step 4
Hi Antoni,
I have planted a ridge gourd. I have been able get exactly 3 gourds. Since then all the gourds are getting dried in their early stages of development. I have attached the images. We also spray turmeric water on it. Please give me some suggestions.
Regards,
Sandeep
2 years ago
Hi: Wonderful informative write up. I am into organic terrace gardening. Want to grow snake and ridge gourd in pots. What size of planter/container would you suggest?
Reply 2 years ago
I am not an expert in terrace garden, but use a larger pot or grow bag for gourd verities. It is important to make a trellis system around the pot / grow bag
Question 2 years ago on Step 14
Hello sir;
I'm planted a ridge gourd plant in 10 gallon Tub, the plant growing very well, but the problem is the plant setting only one fruit at one time and other fruits and buds are turning yellow; I'm using hand pollinateing the buds it's working; and I also used cow manure and banana peels as fertilizers and plant facing the fests like black ants and leafminers;
Please give me some suggestions to make my plant setting more fruits
Thanking u.
