Introduction: Guide on Programming the ATtiny85 Using Arduino Uno
In this instructional guide, we'll explore the process of utilizing an Arduino board as a programmer for the ATtiny85 microcontroller.
To achieve this, we'll employ an Arduino UNO board as an In-System Programmer (ISP) and an ATtiny85 micro-controller. The tutorial will leverage Codebender, an online Arduino Integrated Development Environment (IDE).
By following these steps, you'll be able to effortlessly program both the ATtiny45 and ATtiny85 micro-controllers. Let's dive in!
For this guide, gather the following components:
- Arduino UNO
- Breadboard
- ATtiny85
- 10 uF capacitor
- Jumper wires
Step 1: Introduction to ATtiny85
As per Atmel's specifications:
The ATtiny85 is a high-performance, low-power 8-bit AVR RISC-based microcontroller. It integrates 8KB ISP flash memory, 512B EEPROM, 512-Byte SRAM, 6 general-purpose I/O lines, 32 general-purpose working registers, and various other features. Operating between 2.7-5.5 volts, it achieves a throughput of 20 MIPS at 20 MHz.
Datasheet: [Download Link]
ATtiny85 Pinout:
- Pin 1: Reset
- Pin 2: Digital Pin 3 / Analog Pin 3
- Pin 3: Digital Pin 4 / Analog Pin 2
- Pin 4: GND
- Pin 5: Digital Pin 0 (PWM)
- Pin 6: Digital Pin 1 (PWM)
- Pin 7: Digital Pin 3 (PWM)
- Pin 8: Vcc (2.7~5.5V)
Pin function: ATtiny85Pin Description
Step 2: Arduino UNO As ISP
Here's the "Arduino ISP" code, embedded using Codebender!
Download the Codebender plugin and click on "Run on Arduino" to program your Arduino board with this sketch. Once completed, disconnect the Arduino USB cable from your computer.
Step 3: Connecting Arduino Uno With ATtiny85
Refer to the breadboard circuit schematic in the image above for easy connections. Use the following pin mapping:
- Pin 1 to Arduino Pin 10
- Pin 4 to Arduino GND Pin
- Pin 5 to Arduino Pin 11
- Pin 6 to Arduino Pin 12
- Pin 7 to Arduino Pin 13
- Pin 8 to Arduino 5V Pin
Include a 10uF electrolytic capacitor between the Arduino Uno reset pin and ground.
Step 4: Programming ATtiny85 With Codebender
Utilize Codebender to program the ATtiny85 microcontroller. Connect to your Codebender account and follow the steps outlined in the guide.
Create a new sketch to turn on an LED connected to digital pin 3 (pin 2 of ATtiny85) with a 220 Ohm resistor.
Step 5: Final Steps
Once programming is complete, remove the "programming" wires from the Arduino Uno board. Power the setup with only the 5V and GND cables. Alternatively, use a rechargeable battery (3.7V) or an external power source (max 5V).
Congratulations! You've successfully completed this tutorial on programming the ATtiny85 microcontroller with the Arduino Uno board. Feel free to share your thoughts in the comments, and stay tuned for more tutorials by clicking the Follow button!
