Gypsy Wagon By jaylabrosse in OutsideCamping237,8211,943262FeaturedIntroduction: Gypsy WagonBy jaylabrossewww.facebook.com/JeanMarcLabrossFollowMore by the author: here is the second Gypsy wagon I built along with some friends . I hope you enjoy it.Step 1: Build Your Harbor Freight Trailer ! Step 2: Build 4x8 Box Out of 2x12sStep 3: Floor Subframe Is 2x4s .. You Could Just Slap a 4x8 Sheet on This But I Was Afraid of Deflection.Step 4: Add 3/4 Plywood.Step 5: Screw It All Down With Exterior Grade Deck Screws.Step 6: I Added the Ledges First But in Retrospect I Should Have Done the Gussets First.Step 7: Add You Own Flare Here !Step 8: Screw and Glue All Gussets Step 9: You Could Stop Here and Have Very Cool Wagon Lol!Step 10: Time to Transfer Your Drawing From That Napkin !Step 11: Cut Out Your Shape !Step 12: King Pins Installed Now Hang Your Cut Outs on the King Pins and Screw Them Down.Step 13: Front and Back Walls Are HungStep 14: Side Frame Is 2x2s 16s on Center.Step 15: Dont Forget to Cut These Notches Step 16: Fit Roof Stringers I Used 10 FootersStep 17: Add Insulation to Side WallsStep 18: Cut Out Doors and Windows !Step 19: Fasten Roof StringersStep 20: Used Pneumatic Stapler and Glue to Add 1/4 Ply Walls in and Out. Step 21: The Ceiling Pieces Are Next ! We Used 1 Inch Wood Screws for This Bit. Step 22: Cut and Install More Insulation in Between Stringers and Taped With Heavy Duty Foil TapeStep 23: Time to Add the Bows (1/4 Inch Lath Boards)Step 24: Lay Poly Propylene Tarp and Install Lath Strips Front ,back and Sides . Trim Off Excess !Step 25: Stain and Varnish (or Paint) Your Favorite Color !Step 26: Time to Build Window Frames and Door Frame .Step 27: Trim Over All Your Seems and Around Door and Windows Step 28: Add Window and Door Stops .Step 29: Dry Fit Doors and Windows (all Built With Kreg Jig) Window Are 2x2 and Door Is Made From 2x4 and a Piece of 4/4 Ply. Step 30: Finish Doors and Windows. Cut and Mortise for Hardware .Step 31: Time to Take It All Back Down Add Window Stops, Varnish ,dry Fit Glass. (glass Was From Seattle Stained Glass)Step 32: Install Glass for the Last Time.Step 33: Install Door Windows and Hardware !! Step 34: Install Deck !! Exterior Is Done !!!Step 35: Install Bed Platform and Benches I Also Put Some 110 Outlets.Step 36: Install FlooringStep 37: Install Trim Over All Seems !Step 38: Trim Trim Trim Trim ...trim. Add Curtains and a Bed !Step 39: Finishing Touches Step 40: ENJOY YOUR WAGONS !!
