Introduction: HC05 Bluetooth Module Interfacing With STM32F401CCU
The HC-05 is a very easy-to-use Bluetooth to serial converter. HC-05 connects microcontrollers (like Arduino, STM32) to other Bluetooth-enabled devices. This allows the devices to communicate wirelessly with each other.HC-05 is a Bluetooth SPP (Serial Port Protocol) module designed for wireless communication. It can also be operated as a master or slave configuration.
1.STM32F401CCU Black Pill
2.HC05 Bluetooth Module
3.Jumper wire
Step 1: Connect HC05 Bluetooth Module With STM32 According the Diagram.
NOTE: I've used Black Pill in my case but used a Blue Pill to show the wiring diagram because there was no Black Pill available in fritzing. Wiring will be the same for both boards.
Step 2: Upload the Code to STM32.
HardwareSerial Serial1(PA10, PA9);
const int pinout = PA0; // declare pinout with int data type and pin value
char inputdata = 0; //Variable for storing received data
void setup()
Serial1.begin(9600); //Sets the baud rate for bluetooth pins
pinMode(pinout, OUTPUT); //Sets digital pin PA0 as output pin for led
void loop()
if(Serial1.available() > 0) // Send data only when you receive data:
inputdata = Serial1.read(); //Read the incoming data & store into data
if(inputdata == '1')
digitalWrite(pinout, HIGH);
Serial1.print("LED ON\n");
else if(inputdata == '0')
digitalWrite(pinout, LOW);
Serial1.print("LED OFF\n");
}Attachments
Step 3: Connect to HC05 From Your Mobile. Install Serial Bluetooth Terminal App From Google Play Store.
The link for the application is given below:
https://play.google.com/store/apps/details?id=de.kai_morich.serial_bluetooth_terminal&hl=en_IN&gl=US
Writing "1" in the app will turn ON the LED and writing "0" will turn OFF the LED.
