Introduction: HHO Generator
Hi frnds!
Here I am at my attempt to give you more information about powering engine using water.
This instructable is a part of my previous one. Do visit that one to get a clear idea.
I am posting a video on how to build a HHO generator which will produce HHO gas to power your car's engine.
The video has part 2 for details. It leads you to a site and wants you to buy the guide.
I am posting my version and giving you a detailed information on how to do it.
Let's start!
Let's start!
Step 1: Things We Need
Things we need.
Parts:
1. Glass jar with plastic lid
2. Pet/squeeze bottle
3. 1000mm long braided wire
4. 500mm long water pipe
5. 1000mm long electric wire
6. CD case or thick plastic sheet
7. 2 screws with nut
8. Hollow screw with nut
9. Cheap pen without refill
10. Fuse
Tools:
1. Drill machine with bits
2. Screw driver set
3. Saw
4. Ruler
5. Plase
Parts:
10. Fuse
Tools:
2. Screw driver set
3. Saw
4. Ruler
5. Plase
Step 2: Setting the Plastic Lid
Remove the lid from the jar and with the help of ruler mark the centre of the lid.
Mark four holes for HHO gas, 2screws and fuse.
Drill holes through the marked points and insert screws and fuse respectively.
Now, take the cheap pen and cut near the rear end and insert the piece in the HHO gas hole (watch the video).
Now, insert the water pipe at one of the pen. Connect the wires to the screws.
The lid is now ready.
Step 3: Making the Wire Mesh for Electrolysis
For making wire mesh, take a plastic sheet and divide it from centre. Then cut into 2 pieces using a saw as shown below.
Mark the center of each of 2 pieces and draw a line from the centre to one end. Cut using saw as shown below.
Now, carefully drill holes and cut small grooves at the end of the piece and join them as shown below.
Use the braided wire and cut it into 2 and insert in each of the 2 holes of the plastic sheet. Cover the sheet with the wire as shown below and then connect the 2 ends of the wire to each screw respectively.
It should look similar to figure shown below.
Step 4: Setting Up the Pet/squeeze Bottle
Make a hole and insert the pipe in the bottle. Make sure the pipe reaches to the bottom of the bottle.
Now, drill a second hole and insert the hollow screw there.
This hole is for using the HHO gas. Fill the bottle with water and leave some space for air.
The Center one will pass the HHO gas through water and you will see bubbles coming out. The gas will than escape through the hollow screw which can then be used for combustion.
Step 5: Summary
The assembly is complete.
Fill some distilled water and 3-4 tea spoons of baking soda. Connect the electric wires to 6V to 12V battery to start the process. HHo gas is released from water. It travels through the pipe into the bottle releasing bubbles and escape from the hollow screw.
You can use this gas to run your vehicles engine.
MAKE SURE YOU HAVE SEALED ALL LEAKS.
I TAKE NO RESPONSIBILITY FOR ANY ACCIDENTS AND/OR CASUALTY CAUSED DURING TRYING THIS EXPERIMENT.
VISIT www.hho4cars.com to know more about the use of this gas. Pass on this instructable to all your friends and relatives and let them know the benefits of water.
Enjoy!
Enjoy!
