HIDDEN KITCHEN LID AID
Intro: HIDDEN KITCHEN LID AID
Credits :
This Hidden kitchen Lid Aid is based on Jayefuu's excellent two lid holster instructable.
I had to make very quickly ( while my wife went dog walking with a friend ) and still be
completely removable in case of here unappreciative response
While I am not moving out soon, if ever.
I have a wonderful wife and It is she,
who will decide IF this pan lid hanger is a good idea for her kitchen.
Fun :
For me it is the fun and simplicity of making this lid cradle hanger
which was done faster then the time spent to take pictures documenting it.
Fun :
STEP 1: Step 1: Material and Tools
Tools:
Material:
- a screwdriver
- a pair of small pliers
- a solid metal block
- an old rotary tool grinder
- a metal cutting disc
Material:
- a single length of 3/32" iron welding rod
STEP 2: Step 2: Hang It Up .. Right
Attaching the Rod to the Cabinet Screw :
1. After hand bending the the center Rod dip.
( See First Picture )
2. Use the pliers to make the eye loop for the lower 6-32 cabinet handle screw.
( See Second Picture )
3. A best estimate for length dimensions based on the cabinet door will do,
worst case start another Rod or straighten and re bend the Rod.
4. The metal cutting disc works very well to trim the Rod to a clean end.
( Look Close at Picture )
5. Attach the Rod eye to the lower cabinet handle screw.
( Last Two Pictures )
STEP 3: Step 3: Hang It Up .. Left
Attaching the Rod to the Left Top Hinge :
1. While you undo the top left Hinge SUPPORT THE DOOR to avoid damaging the bottom Hinge !!
2. As before, eyeball the length of Rod needed to hang the Lid knob evenly.
3. Now make a sharp right angle bend with the Rod pointing into the cavity
4. Use the router and metal cutting disc to gouge out a sloping slot in the wood for the Rod to fit under the hinge.
( See Pictures )
5. Also cut and trim the hook Rod right angle edge about 1/8" long and see it fits well into the slot.
6. Then simply tighten the hinge over the Rod.
( See Second to Last Picture )
( See Pictures )
STEP 4: Step 4 : Standoff the Rod Shape
Hanger Shape :
This 3/32" welding Rod has just enough stiffness to be able to stand away from door wall on its own.
Simply pull to bend the Rod out from the door.
Pushing the Rod back against the door using a thick pen or marker as a fulcrum
This will bring a section of the Rod closer to the cabinet door.
Adjust it in and out far enough so that a single hand can easily slip a glass lid into place.
Repeat on the inside of other cupboard doors, for as many pan lids as you need!
Now enjoy your new found storage :-)
25 Comments
Goodhart 10 years ago
iceng 10 years ago
iceng 10 years ago
lime3D 11 years ago
iceng 11 years ago
Jayefuu 11 years ago
iceng 11 years ago
That 3/32" Rod is stiff enough to work with different levels of attachments.
And if you feel you need a more robust Rod they are available in 4/32 ==> 1/8" diameter !
Orngrimm 11 years ago
Thats how an 'ible should be: Simple, genious, practical!
Thanks a lot!
Gathering materials for that next week.
iceng 11 years ago
That was my very thinking when I saw Jayefuu's excellent version of trebuchet's pot lid organizer.
My add was no change to the attachment using the only available hardware..
bajablue 11 years ago
iceng 11 years ago
I bet there is a welding shop near you, even in Baja.
A hanger would also work but might rust with time.
iceng 11 years ago
onrust 11 years ago
iceng 11 years ago
ChrysN 11 years ago
iceng 11 years ago
Thank you :-)
