Introduction: HM-Innovations: Home Made Hookah
Step 1: Supplies and Tools
You need to have the following supplies
A glass bottle, any type will do but make sure that it works with the decoration in the targeted room.
a 12" piece of copper pipe
3" piece of plastic pipe
A hookah pipe
A Rubber stopper
and lastly the Bowl for the hookah.
Now as tools
You need a drill
a blade
and a glass drill bit
A hookah pipe
A Rubber stopper
Now as tools
You need a drill
a blade
Step 2: Drilling a Small Hole Onto the Rubber Stoper
The first thing that you need to do is drill a small hole through the rubber stopper. This hole will hold the copper pipe.
Step 3: Cutting a Hole on the Cap
Using the same size drill bit you need to drill a small hole on the top of the cap, you will place the copper pipe down this new hole as well.
Step 4: Drilling the Bottle
using a glass drill bit, you need to drill a small hole on the side of the bottle that you will be using as a base. One you have that cut out, you can place everything together and see how the hookah will begin to take shape.
Step 5: Attaching the Plastic Onto the Pipe
After you have all of that done you need to attach the plastic tube to the end of your hose.
Step 6: Lastly Place the Hose in the Pipe
Lastly you need to put the hose on to the pipe this will finalize your hookah pipe.
We hope you have enjoyed this project and always be careful when you are using this product. Also make sure that you clean out the pipe just in case there is any glass left over on the inside.
