HOME I/O- Controlling Light Using POT
Intro: HOME I/O- Controlling Light Using POT
DAQ CARD INTERFACING- Analog Control of Home I/O using External Devices
- Control: Connect I/O
- Program Platform: FBD (Inbuilt Connect I/O)
- HOME I/O Environment
Starting Conditions: Home I/O is being controlled by Inbuilt Sensors
I/O Signals
Inputs: Brightness Sensor Analog (Bit 139)
Output:
- Garden Light
- Light Pool Analog (Bit 160)
- Light Porche 1 Analog (Bit 158)
- Light Porche 2 Analog (Bit 159)
Connect I/O Functions to be used
MUL
STEP 1: Wiring Diagram With USB 4704 DAQ Card I/O Solutions:
Input Wiring:
We have connected Potentiometer 5 Kilo Ohm to the Analog Input of DAQ Card as shown. Terminal at left & right end are connected to 5 VDC & Analog Ground of DAQ Card.
The middle terminal of Potentiometer is connected to AI0 of DAQ Card. When we rotate the Potentiometer, we got 0 ~ 5VDC from Potentiometer which goes to DAQ Card and gets converted to Digital value 0.00 ~ 5.00 (Floating Value)
Output Wiring:
We have connected the Multimeter to read the Analog Output from the DAQ Card. The RED lead is connected to AO0 & Black Lead to Analog Ground of DAQ Card.
We are using Multimeter to read the feedback of Analog Sensor in Home I/O
STEP 2: Connect I/O Solutions:
STEP 3: Description of the Functions Used:
Source Bit: This is an ON/OFF bit used to give TRUE/FALSE Signal to Logical gates. When you press it once, it goes to TRUE & when you press is again it goes to FALSE
Bit 139: Brightness Sensor Analog: This is the standardized bit which shows the values in the range (0 ~ 8) corresponding to the Luminance outside the Smart House.
MUL (Multiplication) Function: This function multiplies the value at IN1 & X & gives the result to the OUT
Inputs can be floating OUT = IN1 * X
Bit 160: Light Pool (Analog): This is the standardized float bit used to control the luminance of Pool Light such that it’s luminance changes with the following range:
Decimal Value Luminance (in %)
0 0
2.5 25
5 50
7.5 75
10 100
Bit 158: Light Porche 1 (Analog): This is the standardized float bit used to control the luminance of Porche Light 1 such that it’s luminance changes with the following range:
0 0
2.5 25
5 50
7.5 75
10 100
Bit 159: Light Porche 2 (Analog): This is the standardized float bit used to control the luminance of Porche Light 2 such that it’s luminance changes with the following range:
0 0
2.5 25
5 50
7.5 75
10 100
STEP 4: Explanation of Solutions:
This logic has been made in Connect I/O using the functions & bits explained above.
STEP 5: To Control the Analog Light Using External Potentiometer:
Objective: Following is one the objective which we need to achieve in this activity
To Control the Analog Light using External Potentiometer:
The potentiometer connected at AI0 given 0 ~ 5VDC based on its position. We have connected a Float Output with address ‘0’ which is getting the Digital value in the range 0.00 ~ 5.00.
Multiplication Factor of 2
Now, we know that the Analog Output in the Home I/0 behaves in the range 0 ~ 10 & our DAQ Card range is 0 ~ 5. So we have multiply the value of AI0 with factor ‘2’ & has given the output to Light (Type Analog) to Porche 1 (Bit 158), Porche 2 (Bit 159) & Pool (Bit 160).
STEP 6: To Read the Feedback of Brightness Sensor in Multimeter:
The Brightness Sensor Bit 139 respond to the Luminance of Day light such that when Luminance is 0%, Floating Value is 0 & When Luminance is 100%, floating value is 8.
We have read its value & scale it to the range from 0 ~ 8 to 0 ~ 5 VDC by multiplying it with the factor of 0.62. We are doing the scaling because the DAQ card can give output in the range of 0 to 5 VDC only.
Calculation of Multiplication Factor: 8/5 = 0.62
Want to learn PLC? Get information on our E-Learning courses at http://online.nfiautomation.org
