Introduction: HOMEMADE Super Easy RF Controlled Wireless Switch (universal) FREE Using Old Parts
hi guys!
this is m first project so please go easy on me
well its simple and easy anybody can make it
REUSED OLD PARTS FREE OF COST AUTOMTION
The material required
1:- old RF controlled car
2:- a relay 12v or 6v (12v i used)
3:- old working mobile chargers (1 iv 6v relay / 2 if 12v relay)
4:- a switch and a socket
5:- Soldering iron
6:- hot glue
7:-wires ,screws, screwdriver, a breadboard etc
8:- some ply board / plastic board/ hardboard /cardboard for housing
9:- a dc on -off switch
Step 1: MATERIAL REQUIRED
Step 2: CIRCUIT DIAGRAM
Step 3: Preparing the Circuits
Extract the car chip as shown and Remove the upper casing of charger and cut the wires
Step 4:
Mount the relay on the bread board and connect wires to it
i had a 5 p relay if u have one with 4 pins its ok both works great
Step 5:
cut a piece of cardboard or any housing material u wish to use (FOR BEST IT SHOULD BE OF MINIMUM SIZE POSSIBLE ) and mount the ac input plug
Step 6: Attach Charger to the Plug
attach the charger AC input to the plug
if 12v relay then put 2 chips together as shown in circuit above
Step 7: Wire Cars RF Chip AND Antenna
connect the dc output of charger to the input of cars RF chip and try to make it as close as possible to reduce overall height
now connect the output wires of RF chip with the coil of relay
(if 12v the make connection as listed above)
for antenna connect the wire to antenna to extent it
we gonna place it on the top of housing
Step 8: Adding the AC Socket
now add the AC socket for this take another piece if cardboard equal to the bottom one and mount the socket on it
wire it as shown in the circuit
Step 9: Adding the Housing
for the measure the dimensions of your circuits and cut 4 walls of cardboard for your housing
then paste then together
with housing
(BEFORE PASTING TEST THE CIRCUIT )
Step 10: MODIFYING THE REMOTE CONTROLL
Now grab the remote control most of them have click switches so we need to replace
for this
You can use any available on-off switch.
Step 11: THE FINAL PRODUCT WILL LOOK LIKE THIS
i Hope you will make i better then me
if any queries feel free to ask
