Introduction: HOMOPOLAR Motor That Can Be Made at Home
This is an instructable that will show you to make a motor out of things you have lying around the house
Step 1: Materials
D-battery,
Flat magnet,
Rod of some sort(I used a screw),
Copper wire,
Casing(optional),
Flat thin piece of plastic(optional),
Switch(optional),
Step 2: Assembly
Put the screw on the negative part of the battery. Next you need to put the magnet on the screw head(you see why I use a nail) and finish the circuit by attaching the wire to the positive part of the battery and touch/attach the other end to the magnet
Step 3: Optional
After everything else you may get casing and use a switch that will move the plastic in between the wire and positive section of your battery cutting off your circuit saving energy and making practical use possible (sorry but I have no pictures of this)
Step 4: WARNING
this motor can fly apart if not secured and you'd probably not like a screw in the eye
