HOT Glue Easter Egg
Intro: HOT Glue Easter Egg
A fairly simple Easter egg made out of hot glue.
STEP 1: Gather Materials
You will need and/or want the following items...
-Hot Glue Sticks (LOTS!!!!!)
-Hot Glue Gun
-Plastic Easter Egg (The kind that breaks in two easily)
-Fat Max Razor
-Needle Nose Pliers
-Hot Glue Gun
-Fat Max Razor
-Needle Nose Pliers
STEP 2: Make the Base
Take the stubby half of your egg and fill it to the rim with hot glue. Make sure that you have a piece of paper under your working area to reduce the mess. Then allow it to dry.
STEP 3: Make the Top Half
Fill the longer half of the egg to the rim and set aside to dry.
STEP 4: Remove the Plastic
Grab the smaller end. Use the razor to cut the plastic and bend it enough for the pliers to be able to clamp on the plastic. Then peel the plastic away gradually. Caution, SHARP EDGES!
STEP 5: REPEAT!
Repeat step 4 with the upper (elongated) half.
STEP 6: Touch Ups!
Touch up each half by using the razor to flatten out severely uneven edges. (Don't get too picky!)
STEP 7: Bond the Halves
Put a layer of hot glue on one half of the egg (on the flat side). Then take the other half (flat side) and stick it to the glue. Hold for a couple seconds. Then fill in all the cracks around the "binding" glue. You can use the metal part of the glue gun to smooth things out.
STEP 8: Finish Up! Clean Up!
Make your finishing touches with the razor and glue gun. Allow your egg to cool. While it is cooling, put all your supplies away. Once the egg is cooled, have fun. You can decorate, play pranks, invent games, play catch, or do anything you would want to with a crude looking, artificial egg. Don't forget to leave comments!
32 Comments
dragonslug 10 years ago
If you used clear hot glue you could drill a hole in the bottom/ insert an LED and coin cell and have it light up. Just a suggestion.
Mplinnc 13 years ago
captain Jack 13 years ago
bassclarinet23 13 years ago
Bongmaster 15 years ago
frollard 15 years ago
micklame2014 15 years ago
The Ideanator 14 years ago
bassclarinet23 14 years ago
Comment Revision: You say geek like its a bad thing. Without us, you couldn't complain to us here on the IntErNetSS. Without us, you would still be hitting small, furry squirrels with rocks and eating them raw because nobody bothered to invent fire.
I politely request that you return to commenting on all things that are not Instructables, such as youtube vids
Either way its funny.
INSTRUCTUBAL 15 years ago
frollard 14 years ago
