Introduction: HOW TO ASSEMBLE AN IMPRESSIVE WOODEN ROBOT ARM(PART3: ROBOT ARM) -- BASED ON THE MICRO: BITN
The next installation process is based on the completion of the avoiding obstacle mode. The installation process in the previous section is the same as the installation process in the line-tracking mode. Then let's take a look at the final form of Armbit - the installation of the robotic arm.
Step 1: The Assembly of Armbit ( Robot Arm)_1
Needed parts:
- Robot bracket Kit
- Screw package
- Screwdriver
- Anti-blocking servo
In this section, we need to install the arm part of Armbit.
You need to install a part of the body as shown in the picture. It is only necessary to fix the small blocks with screws, and then use screws and servos to fix them together. During this process, pay attention to adjusting the tightness of the screws. Pay attention to adjust the tightness. This process tests the hands' ability of 3 stars
Step 2: The Assembly of Armbit ( Robot Arm)_2
Needed parts:
- Robot bracket Kit
- Screw package
- Screwdriver
In this section, we install the right side of the robot arm. Pay attention to the tightness of the screws and the direction of the arm during this process. This process tests the hands' ability of 3 stars.
Step 3: The Assembly of Armbit ( Robot Arm)_3
Needed parts:
- Robot bracket Kit
- Screw package
- Screwdriver
In this section, we have installed the left part of the robot arm and combined it with the left part of the robot arm. Pay attention to the tightness of the screws and the direction of the arm during this process. This process tests the hands' ability of 3 stars.
Step 4: The Assembly of Armbit ( Robot Arm)_4
Needed parts:
- Robot bracket Kit
- Screw package
- Screwdriver
You need to install the claw as shown in the picture. Only need to fix the small wooden block with the corresponding screw. This process tests the hands' ability of 3 stars.
Step 5: The Assembly of Armbit ( Robot Arm)_5
Needed parts:
- Screw package
- Screwdriver
In this section, we need to combine the claw and arm sections together. This section pays attention to the tightness of the screw.
Step 6: The Assembly of Armbit ( Robot Arm)_6
In this section, we use the line to combine the assembled arm and body parts of the previous step to assemble the final form of the robot arm.
Step 7: The Assembly of Armbit ( Robot Arm)_7
Finally came the final step. In this section, we wrapped the exposed wire with a wrapping wire, which finally ended the installation of Armbit's last form manipulator.
Step 8: Its Gameplay
The above shows the gameplay in the robot arm mode.It is all about the installation of the three forms of Armbit.
Hope Armbit can be a good partner in your study and life!
Have fun~
