HOW TO CHANGE/RECOVER ADMINISTRATOR PASSWORD
Intro: HOW TO CHANGE/RECOVER ADMINISTRATOR PASSWORD
In Case, when You Forgot your Administrator password, it is difficult to recover/change It.
But with some little Fun of CMD commands, you can do it with ease.
Surf it! Learn it! Share it!
Follow me For some more stuff Like tHis...
STEP 1: Step #1
You can adopt this Trick In Case when You forgot Your administrator password..
ALL YOU NEED IS TO OPEN "CMD" WITH ADMINISTRATOR PRIVILEGE
(you can do it by searching for an cmd.exe file then right click on it and run as administrator)
NOTE: THIS TRICK WILL ONLY WORKS IF AND ONLY IF YOU ARE A ADMINISTRATOR OF YOUR PC
And So if you are a administrator, just goto cmd and then proceed to Step #2
STEP 2: Step#2
after running cmd.exe as administrator, You will see a cmd like in picture provided.
-So just type:
net user
-then press enter
(it will show you the list of accounts available in your pc)
-then proceed to step #3
-So just type:
net user
-then press enter
STEP 3: Step#3
so you can see the list of accounts right! (differs with your system).
Here in this case i'am going to change administrator password because i(user) forget administrator password.
Information:
since we know, for everytime you change your account password, windows will firstly ask for current password and then the new password and so on check!
but if you forgot your current administrator password then it creates problems, but to overcome this:
1-your pc have to run on administrator /administrator privilege
then this trick will be very useful for you(users).
see step #4
Information:
see step #4
STEP 4: Step#4
so here in this case, we want to recover administrator password, so i type:
net user administrator * (press enter)
(type your new password and press enter)
(again type your new password and press enter)
Information:
With administrative privilige, you can also change your local accounts password too by following the same format:
net user (account/user name) *
then set your new password.
Information:
STEP 5: Step #5
Now just sign-iN,LogiN or whatever with a password you set in step #4
belong to specific account name.
In This Instructable:
here we change administrator password.
so administrator password is now change without knowing the previous one.
This trick helps alot to recover.
7 Comments
cinthy1954 7 years ago
can't get command promp...not even with safe mode....won't boot from disk either
marieemma 8 years ago
I haven't started yet, but I will let you know how it goes.
faizank2 9 years ago
awexome nd nyc ;)
shinna.jeffrey 9 years ago
wow! its a magic
Johnaiden 9 years ago
Nice guidance! There are 5 steps in your post
to change/recover the administrator password. I know another way which can
achieve this just in 3 steps. It is a third-party tool called Windows password
key enterprise. I used this tool to change the lost old password and create a
new one. For more info you can search on google.
Techshot 9 years ago
seamster 9 years ago
Good ideas. Thanks you!
