Introduction: HOW TO CONTROL AN RGB LED WITH ARDUINO! 2 MINUTES
How to control an RGB LED with the arduino!
WHAT YOU NEED~
RGB LED
ARDUINO UNO, YUN, MEGA, PRO MINI, NANO, ECT
6 JUMPER WIRES
BREADBOARD
3 100K OHM RESISTOR
Step 1: The Led
The led legs are easy to understand the longest must be connected to the 5 volt pin of the arduino, and the shorter legs must go to a 100k ohm resistor connected in the following pattern~
RED- PIN 9
GREEN- PIN 10
BLUE- PIN 11
^^All connections are on the schematic above^^
Step 2: Coding
int redpin=9; //Pin 9 int greenpin=10; //Pin 10 int bluepin=11; //Pin 11 int var=0; int var1=0; void setup() { } void loop() { for(var=250;var<255;var++) { analogWrite(redpin,var); //RED analogWrite(greenpin,0); delay(500); analogWrite(redpin,0); //GREEN analogWrite(greenpin,var); delay(500); analogWrite(greenpin,0); //BLUE analogWrite(bluepin,var); delay(500); analogWrite(bluepin,0); delay(500); } for(var1=250;var1<255;var1++) { analogWrite(redpin,var1); //YELLOW analogWrite(greenpin,var1); delay(500); analogWrite(redpin,0); delay(500); analogWrite(greenpin,var1); //CYAN analogWrite(bluepin,var1); delay(500); analogWrite(greenpin,0); delay(500); analogWrite(bluepin,var1); //MAGENTA analogWrite(redpin,var1); delay(500); analogWrite(bluepin,0); delay(500); analogWrite(bluepin,var1); analogWrite(redpin,var1); analogWrite(greenpin,var1); } }
Step 3: Finished
Now that you have finished coding and wiring it is time to test if it doesn't work you can troubleshoot or comment!
THANKS FOR VEIWING!
FOR MORE~
