Introduction: How to Fix a Zipper (without Replacing It)
This is a easy way to fix a zipper without replacing it. This method is really fast too. It works when the zipper pull doesn't close the zipper together anymore. I don't really like to replace zippers, because they always come out a little bit wavy when I do it myself.
You can save a jacket, a tent, a sleeping bag, and many other items.
Step 1: What You'll Need
You will only need a pair of pliers.
But if the zipper pull is really destroyed or is made of plastic you will need a NEW ONE OF THE SAME SIZE. YOU CAN FIND IT IN ANOTHER OLD JACKET. Or you can buy one online for really cheap.
Step 2: Remove Stopper
Remove the little iron stopper of the top of the zipper, which will be on the same side of the jacket where the zipper puller is.
(Sometimes they are made of plastic, so it is little more difficult to remove and replace. You may need to substitute it with few knot of thread or something else. There is many tutorial out there on how to replace a stopper).
Step 3: Remove Zipper Pull
Remove zipper pull. You can probably see that it is all distorted.
Step 4: Adjust the Zipper Pull
(ONLY FOR IRON ZIPPERS)
With the pliers close the two sides of the zipper pull, try to make it look like the original shape again.
If your zipper pull is not too worn out you can try to close it directly on the zipper, without removing it.
(if it is made out of plastic, if it is too bent or if it breaks doing this, you need to find another one of the same size, they are available online, or you can take it from another old zipper).
Step 5: Put Back the Zipper Pull
Put back the zipper pull. It may take a little bit of time...
Step 6: Put Back the Tooth
Put back the iron tooth with the pliers.
Step 7: Done!
Done!
Faster than changing it!
![Fix It Contest](https://content.instructables.com/FU6/9YHD/HGU2DIDY/FU69YHDHGU2DIDY.jpg?auto=webp&frame=1&width=320)
First Prize in the
Fix It Contest
![Instructables Green Design Contest](https://content.instructables.com/F7Y/91K9/HFSHSF51/F7Y91K9HFSHSF51.jpg?auto=webp&frame=1&width=320)
![Epilog Challenge V](https://content.instructables.com/FGP/FD19/HFBKEI2U/FGPFD19HFBKEI2U.jpg?auto=webp&frame=1&width=320)
Epilog Challenge V
