Introduction: HOW TO GET STARTED IN MINECRAFT
Today I will be teaching you how to get started in Minecraft and if you are playing for the first time you. Have come to the right place to learn and I hope this is helpful.
you will need is Anything devises or consuls with Minecraft on it such as PS PC Samsung Apple Wii Android and Xbox
Step 1: CREATE YOUR WORLD
If you are just starting I would suggest survival and for difficulty level I think normal would work. Not too easy and not too hard and if you really want to spawn with a map and a bonus chest. Be my guest and go ahead but if you want to get proper achievements I would not suggest it.
Step 2: START YOUR ADVENCHERS
When you spawn, start with getting wood and once you have wood. Go to your inventory and craft some wood planks and with the wood planks. Craft a crafting table then craft some sticks but don't do that to all your wood planks
Step 3: BUILD YOUR HOUSE
I would use wood logs, wood planks, cobblestone, glass blocks, cobblestone stairs, for the roof and to get up and down floors start with 4 wood log. Towers 8 blocks tall and 8 blocks apart from each there turn the ground on the inside of the wood pillars cobblestone. Then fill the empty wall space with wood planks, fill in a 6 block long 1 block hue with glass and do the same thing on top. Of the glass and do the same thing in the other walls make a second floor 3 blocks hue and build a stairs. Then cover the roof with cobblestone then build stairs on the roof to make it more like a roof and if you want to add more design be my guest.
Step 4: THE FINAL SENSES
I hope this was helpful and that you enjoyed. It and thank you for using my Instructions on how to get started in MINECRAFT bye.
