Introduction: HOW TO MAKE DECORATIVE NAPKIN RING HOLDERS
These easy to make napkin rings will brighten up any country
table setting. They can be used to hold a napkin or wrap your silver ware in a napkin and slip it into these rings for a classy look! Fresh flowers or Herbs will also decorate your table in these cute rings
You will need:
· Glue gun and glue stick
· Burlap Ribbon: either plain or with lace already on it.
· Sheer Ribbon: Pick a color to match your decor.
· Lace Ribbon: If you chose burlap ribbon that does not already have lace.
· Scrap Material (optional from your scrap material bin).
Now comes the easy part!!
Step 1: Decide Which Burlap You Would Like and Cut Pieces to Size.
Decide which Burlap you would like and cut pieces to size depending on the item you are holding with it. I used about 8 to 10 inches for the large one and 6 inches for the small.
Step 2: Cut Lace Ribbon to Size of Burlap and Glue Ribbon.
Cut Lace Ribbon to size of Burlap and glue ribbon evenly in the middle of the Burlap. If you would like, first glue a piece of scrap material and then when it dries, glue the lace to the material.
Step 3: Form the Burlap Into a Ring and Glue Ends.
When the glue has dried, form the Burlap into a ring and glue ends together.
Step 4: Tie a Piece of Ribbon Around the Ring to Finish Off the Look.
Tie a piece of ribbon around the ring to finish off the look.
That’s all there is to it! I used the large one to gather a piece of Burlap runner for a table setting.
